Results 1 to 14 of 14
Thread: Advise on my T5 gearbox
    VN Calais V6 Manaul
    Jan 2005
    Default Advise on my T5 gearbox
    G'day guys, I just recently got a fully reco'd T5 gearbox for VN-VN V6. I was interested to see if you guys would recommend me replacing anything else and what oil I should use, the guy at the shop I got it from said I use transmission oil or transmission with a mix of gearbox oil if I was going to give it a bit. I was a bit confused by this so I thought I'd see what everyone else thought. Also one other thing I will be changing will be the clutch as well, I wanted to replace it with a heavy duty clutch, could I please get any recommendations on which brand and model is a good one for my type of gearbox?
    Cheers, mickah
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    well i use the oil specified by holden cant remember wat it is but repco and supercheap have it
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Holden specify Shell Oil, can't rememebr what type.
    NEVER put any type of transmission oil in there, its too thin. as with don't put gearbox oil in a transmission, as its too thick for the bands.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VN series III & Honda VTR250
    May 2005
    sydney
    from memory the grade is 70/85? mate where did you pick up the t5 from and for how much, also if anyknows if a sedan and wagon manual have the smae length mainshaft?
    cheers
    CBR954RR
    XR400R
    dont knock riceburners, they are fast and reliable...
    rare and endanged 94 VR auto white sedan
    STEALTHY™'s Avatar
    Jan 2005
    if you mean tail shaft, then no. the LWB cars have a longer tail shaft, so if converting a Statesman or wagon to manual, you'll need the tail shaft from a manual wagon.
    cheers sexy
    VN Calais V6 Manaul
    Jan 2005
    What about clutches, what's a good heavy duty one? I couldn't imagine there would be that many for the T5, so there should be a preferred one that everyone agrees on.
    VN Commodore
    Feb 2006
    get a heavy duty pressure plate. i have one.. it is good i reckon. in one of my other cars i have a heavy duty pressure plate and a ceramic clutch plate. it is unreal. nice and smooth..i think i will put one in my commodore if i ever need a new one. they are also very grippy too.. don't slip.
    VN Calais V6 Manaul
    Jan 2005
    STEALTHY™'s Avatar
    Jan 2005
    clutches are just as wide ranged as any other car part.
    I use an Extreme clutch, never had a problem, except the fact its too strong and my gearbox is the weakest part of the driveline.
    Don't make that mistake, its cheaper to replace a blown clutch for around $300 every time instead of $2000 every time for a new box!
    cheers sexy
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    bonglung Guest
    T5's require Dexron Type III. Auto oil with a additive for the bearings. Most reputable places will tell you to run auto oil and thats it.
    I run Fully synthetic castrol in mine since I rebuilt it and haven't had any dramas yet. I wouldn't mind trying an additive to see if I can shut that damn input shaft up while the aircon is on.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by bonglung
    Holden State in the manual never to use Auto oil in the gearbox, so there word is good enough for me.
    If you run auto oil, eventually it'll get too hot and burn everything out
    cheers sexy
    LowVp's Avatar
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    wtf who said to use auto oil in a manual box, the auto oil would not handle the heat or the pressure.
    shell X75/90 Gear oil, 2.05 Litres
    or any similar weight hypoid gear oil
    bonglung Guest
    Quote Originally Posted by STEALTHY
    The getrags use gear oil I believe, but the T5's use auto oil.
    Page 14 of the Gregory's repair & service manual VR
    Manual transmission:
    Lubricant Type: Dexron III and 150ml of Lubrizol 7906
    Capacity 2.05 Litres
    *cough*
  1. tyre advise
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2007, 07:28 PM
  2. i need some advise on a mod i am doing help
    By peter j in forum V8 Development and Modification
    Last Post: 15-11-2006, 08:39 PM
  3. VL on LPG advise
    By Stewart1000 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2006, 05:06 PM
  4. advise
    By 16 vk boy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-06-2006, 07:58 PM
  5. a little advise
    By jazzawithvg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2006, 10:32 PM
