Results 1 to 4 of 4
Thread: Which stroke?
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Default Which stroke?
    Hi!
    I need to know how a vp v6 motor and ecu can tell whether it is on compression stroke or on exhaust stroke....
    my car seems to be backfiring and blowing exhaust out the inlet - with a new crank position sensor.....
    Ideas?
    Luke.
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Incorrect installation? Either that or perhaps your leads are in the wrong order.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    Aug 2004
    S.E. Melb
    umm the valve opening and closing is all mechnical remember, the ecu cant control when they open... I suggest that if its blowing exhaust throught he inlet, its dropped a valve?
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    yea i know it's all mechanical (although it'd be a much mroe efficient and powerful motor if valves were solenoids - electronic cam that changes as you boot it!)
    I was thinking along the lines of that it's giving it spark and fuel on the exhaust stroke, as opposed to the compression stroke, then by the time whatever's left of the mixture ignites, the inlet valve is open and fires out the intake.
    however, it turns out it doesn't matter whish stroke it's on as long as teh timing is all correct.
    problem lied in the DFI module - i'd tested another one, but there were other problems that stopped it from firing...
    i ended up testing it again after eliminating a lot of other things
    and worked nicely.
    car = good now
  1. 2 stroke fan or 4 stroke fan?
    By calais_304 in forum Just Commodores Polls
    Last Post: 25-07-2009, 05:39 PM
  2. to stroke or 8?
    By Low_VX_Taxi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2007, 10:45 AM
  3. to stroke or not to
    By stockvp in forum V6 Development And Modification
    Last Post: 20-02-2006, 07:06 AM
  4. Stroke my V6
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 04:52 PM
