Hey, couple quick q's.
is vn ss fuel tank same as normal vn (capacity etc)? trying to sort out a towbar n since it goes under the fuel tank im guessing the tank size affects which towbar gonna fit
also are vn vp vr vs towbars all same? ie a vs towbar gonna fit my vn?
i got a towbar on my vp i wanna get rid of u can have it if u come get it
Hey man , the VN SS Runs a 80 litre long rang tank , same as normal V8 VN. Not sure if other tow bars will fit from other models.
I thought it was a 90litre tank..... I had towbar on my old VNSS no problems, they didn't even have to cut the rear skirt.....
" Behold the turtle. He makes progress only when he sticks his neck out "
i know my 1990 vn ss has a 63L tank, not 80 or 90L.
cat? isnt that an animal? no i dont want one in my exhaust system thankyou very much...
my ride \/
http://forums.justcommodores.com.au/...ighlight=seabs
My 90 ss has 63L tank.
Well they must have been change because the SS came out with a long range fuel tank...
My VP has the 80 liter tank, not that I've ever filled it but parking beside the V6 you can clearly see that the tank is different, I guess a few V8's would have damaged the tank over the years and had a V6 one put back in, if it was easier to get hold of or they just didin't realise the two were different
Standard issue on VNSS was80
