Results 1 to 7 of 7
Thread: VN Misfiring
    VT Wagon
    Apr 2006
    Default VN Misfiring
    Hi,
    My 5-speed 3.8L VN has been misfiring the last few weeks, particularly when going uphill or when giving it a bit of stick. The car can be driven softly to avoid the problem most of the time put this is not an ideal solution. The car has relatively new spark plugs and leads, so I think it may be an ignition coil problem. Any ideas/advice would be greatly appreciated.
    Cheers,
    Luke
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    I reckon you'd be right in what you think. Sounds a lot like a coil pack problem. An easy way to 'test' (although not completely accurate), is to go for a bit of a drive, then see how warm each of the coil pack modules gets. If one is a lot hotter than the rest, it's normally a good indication that it's buggered.
    Is it a series 1 or series 2 VN? If it's a series 1 it would be a good chance to upgrade to a series 2 coil pack setup, just a bit more spark.
    Gravity is proof that nature keeps getting us down.
    beefcream's Avatar
    beefcream is offline Lethal LOKKA
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    ive had this twice now.. most likley ur coil or faulty dfi module
    expensive bastards!
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    AdamIan69 Guest
    i have had the same problem with my VN, i have replaced coil packs and DFI module, map sensor spark leads and i have reletive new plugs? i am starting to think it has somthing to with the Crank Angle sensor as it only misfires under load and when the engine is at operating temperature. Has anyone got any ideas?
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    if its the crank angle sensor dont u put some cold water over it and see how it goes. if its better then theres your problem
    mouce's Avatar
    Jul 2005
    If it's CAS, either it works or it doesn't. Yeah...dumping water on them cools them down so that they start working again, but I've never heard of a CAS leading to a misfire, only stalling.
    That said...I could be wrong.
    AdamIan69 Guest
    i took my VN for a drive tonight waited till it got to full operating temperature, and then pored 2 litres of water over the Crank Angle Sensor, to cool it down. it didnt completly stop the miss, but helped it considerably. ( i cant imagin 2 litres would have made the CAS completly cold again though, give it a go and tell me how you go.
  1. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  2. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  3. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  4. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  5. misfiring
    Last Post: 18-06-2006, 11:36 AM
