Results 1 to 12 of 12
Thread: Headlight Bulbs
    VN Wagon
    Feb 2005
    Default Headlight Bulbs
    The standard H4 bulbs are 60/55W, can I just swap them for 100/80W or do I need to upgrade the wiring/fuse/relay? Or should I just buy better quality 60/55W?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    60/55 are fine, go for the 100 watters if you do alot of country driving but then you will have to upgrade the wiring which isnt cheap
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    or buy narva plus 50s or philips vision plus's, they both give 50% more distance of light. theyre both still 60/55w
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    I did have a set of 100/80w globes in there, after 4 hours on high beam one night cruising at 110kph, I had sucessfully melted the fuse (not blown the fuse, but melted the plastic casing on it), melted the relay housing, and the holder, and had the insulation dripping off the wire leaving expose wires in the engine bay.
    If you want some better lights, go out and get a REAL set of driving lights, and one of those bars that bolt onto the bumper with the number plate (that way you can remove them when you don't want them to be stolen). Would probably workout to be just as expensive as upgrading the wiring, and all the other crap that goes with it.
    Gravity is proof that nature keeps getting us down.
    VN Wagon
    Feb 2005
    VN Wagon
    Feb 2005
    Checked out my lightbulbs. One was a Lumen and the other was an Austa. Replaced them with Philips Premiums and it improved the light output significantly.
    So don't buy el-cheapo brands!
    Funnily enough the Philips bulbs were about the same price if not slightly cheaper.
    hakhawk's Avatar
    Jan 2005
    1991 VN Berlina S/Wagon v6 auto
    Apr 2006
    hakhawk's Avatar
    Jan 2005
    VN Wagon
    Feb 2005
    Have a look at the other 60/55W upgrades as well. My point is that the Lumen and Austa were sub-standard and in my view dangerous to use at night.
    Apr 2006
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Just put a set of narva bull lamps on it you'll see for miles they will shine up to 1.7 klms ahead
    I had a set om my patrol, brightest lights on the road and only $89 a light from queensland deisel spares!
    awesome lights they light it up like daylight.
  1. Projector headlight bulbs
    By commodore2004 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2007, 02:46 PM
  2. Max power bulbs for my car?
    By b3h3m07h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2007, 06:36 PM
  3. Xenon Headlight Bulbs
    By Troy711 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2007, 09:03 PM
  4. Headlight Bulbs
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 09:03 PM
  5. Cluster Bulbs
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 04:37 PM
