Results 1 to 9 of 9
Thread: MAP sensor error!!
    Vz Sv6
    Jul 2005
    Default MAP sensor error!!
    hey all,
    got my car back yesterday from the mechanics and now im getting error code
    33 which is MAP sensor. Question is wat does the MAP sensor do and what are the side effects of a broken MAP sensor?? it has stalled on me once so far, so i am planning to get the part 2moro.
    also i have checked the vacuum hose going to it and it doesnt seem to have any cracks or leaks, should i replace that aswell any way??
    thanks
    VP Executive R-spec
    Jan 2005
    The MAP sensor is probably the most important part in your car, but I haven't read of anyone breaking one before, did the mechanic have that unplugged?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Vz Sv6
    Jul 2005
    doubt he would of touched it.
    now i cant even start my car, reset my ecu and no error codes but still no start! i have had the code one other time in the past but got told by the racv guy that it was because my fuel pump was playing up and the ecu thinks many things when it doesnt have fuel. well so far my fuel pump has been good *touch wood*
    anyway, i will going try and start it later.
    cheers
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    The map sensor is basically a barometric pressure sensor that tells the computer basically where the vehicle is situated in relation to sea level. It is therefore similar to a coolant temp sensor in its operation in how much fuel to allow the injectors to inject. An easy way to test is to connect a scanner to the vehicle and check the map sensor reading prior to starting as to an experienced mechanic the reading is very important. If the sensor is failing it will not inject enough or inject too much fuel into the system and cause the vehicle to not start or stall. There are basically no diagnostic checks for this unit and must be checked with a scanner. The hose is very critical too and there must be no kinks or breaks and the length has to be exact, so you can't just replace with any length of hose. Hope this helps!!!
    VP Executive R-spec
    Jan 2005
    The MAP sensor is your Manifold Air Pressure sensor is tells the ECU what kind of load the engine is under and how much stick your giving it and the engine uses that vs RPM to calculate how much fuel and how much spark to give the engine, like I said, verrrrrrry important part, it's just about all the VN-VR use to make the engines run the VS onwards use a Mass Air Flow meter instead which is a bit more uncool
    Vz Sv6
    Jul 2005
    just changed the MAP sensor, only cost me $55, so im pretty happy. hope it fixes all my problems
    vn s1
    Oct 2011
    Goorambat
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by hangvn View Post
    where is the map sensor on vn ?
    On a Series one V6, it is a black rectangular plastic box located nearly central on the upper part of the firewall.
    BTW, the acronym 'MAP' actually stands for Manifold Absolute Pressure, not Manifold Air Pressure.
  1. Error 33 Map Sensor
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2011, 09:41 AM
  2. Error code 41, Crankshaft Sensor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:23 PM
  3. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  4. Error 33 - MAP Sensor voltage high / vacuum leak
    By shaggerz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 09:06 AM
  5. error, error !!
    By dahlyla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2005, 07:57 PM
