Results 1 to 5 of 5
Thread: getting axel out of diff
    VP WAGON V6
    Mar 2006
    Default How do i Remove a Diff Centre
    ok im trying to get the diff centre out of my wags. Ive got the axels out, got the back plate off got the 4 bolts that hold it in out. Now i have to take the centre out. HOW DO I DO THiS.. I have no idea how to do this and there is nothihng about it in the gregorys manual. Just says take to a specialist. I know it can be done at home so can someone hlep me... PLEASE PLEASE PLEASE PLEASE
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    do you know what sort of diff it is? borg warner? salisbury? so you got the backing plate off, the axles are out, and you say you have taken the four bolts off the hold the bearing caps, well now you need to remove the caps, and then i cant remember how to get it out. someone else will know, but why may i ask are you removing the centre? if you are going to rebuild it or overhaul it you will need some gauges, to set everything up properly so you dont get a wining sound
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    lol
    im guessing its a 9 bolt since your title says vp
    the reason i started with lol is because you have done everything you need to do to get it out.
    if you grap a large metal pipe ir a crowbar then just lever the center out against the diff housing and with a little force it will slide out and your shims will come out with it so be carefull to note the side and direction they were in... (make sure its clean and dont scratch any metal as filings wont go down to well in the diff .. you may like to completely clean the diff to solve this)
    you would normally use a housing opener to open the diff a few thou to allow you to pull it out with your hands. you dont need this ive done it before with no problems and i just tap the centre and shims back in with a rubber mallet or a block of wood and a hammer
    im not admiring your car im looking in disgust
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    yupyup ^ spot on
    a metal pipe, with the inside of the pipe around one of the diff center bolts, then pry it out by levering it against the housing
    it just needs a little negotiation with some force (but careful not to bend break or scratch anything)....
    there's nothing else holding it in, it's just squeezed in there.
    VP WAGON V6
    Mar 2006
    yepo i got it out.. was simple as, as soon as someone told me its only sitting in there now. Getting it back in was a problem. Took about 5 goes and somme real effort. Whoops anout the marking/scrathing stuff. There are some BIG hammer marks in there now. OHhhh well doesnt matter. I have anoyher diff sitting here if i need it. I took it out cause i wanted to lock it for a burnout comp on saturday.
  1. VN/VP tailshaft IRS/live axel compatible?
    By V85000i in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 08:13 PM
  2. Axel assembly replacement
    By kizza231188 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-04-2007, 10:13 AM
  3. WTB: 2.5" VN Live Axel Exhaust [melb]
    By HoZy in forum Swap / Wanted to Buy / Trade
    Last Post: 31-01-2007, 07:07 PM
  4. Axel fix
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2006, 12:32 AM
  5. Rear Axel Trouble...
    By tbaussie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 11:36 AM
