Results 1 to 21 of 21
Thread: Girl needs help
    missmcudd's Avatar
    missmcudd is offline The Bee Sting butterfly
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    Default Girl needs help
    ive taken to the liberty of fixing my car myself with a dent that it had in the side (i love you bog) and a pannel that was ruined when theives tried stealing my rims.
    See pictures below
    Anyways my front bumper is hanging down really bad both sides and im dumb and cant figure out whats wrong. I think theres clips broken but it just dosnt seem to want to straighten up. Can anyone explain to me how to fix my front bumper and make it straight or how to tighten it up or what ever so i can take it to the spray shop after easter?
    Please be mindful im a girl and this might sound stupid but hey im learning..
    take it easy and if its easy ....take it home!
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    The clips they came out with must be pretty bad, most VN-VP's I have seen have the bumpers hanging off at the ends. Mine is, but it's not too bad. You can buy replacement clips, but I'm not sure how you install them. I have some here for mine, but have no idea how to put them on!! If i work it out i'll let you know!
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    vn4play Guest
    hey if you hop under the front of your car you will see two support brackets that bolt to the chasis from the front bar if you loosen the two bolts you can support the front bar at the angle you want and do them back up, also there is a plastic clip on the front gaurds that may have popped out if that is the case just remove the bolts from the mount on the chasis, slide your front bar forward line up the plastic clip and slide it back. then do the bolts back up.
    hope this makes sense and i hope it helps you.
    missmcudd's Avatar
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    Thanks guys i really appreciate it. Ill give it a go this weekend, if anyone has got pictures to help me would also be appreciated!
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by missmcudd
    here is a pic of the plastic clip mine didnt even have one when i got it. u can get them from the wreckers for a few dollars
    Adam
    vn4play Guest
    yeah also check the one on the bumper(sorry dont have a pic) also a problem on them is the little metal lugs holding the plastic brackets can snap thats what happened to mine (left side of car can be replace right side needs tack welding back on) i got the new plastic clip on the body side for $8ea brand new from holden(wreckers were wanting $10) and the right side bracket with lugs from wreckers for $10.
    If you undo the 4 bolts on the bracket that holds the front bar to the chasis and wiggle the front bar side to side slowly whilst pulling forward(dont pull down, you will brake the plastic clips) you will free the front bar from the car to see if anything needs replacing! then if anything is not broken you can just slide the bar back onto the plastic clips then do up the 4 bolts so the bar is lined up properly(i use a mate to hold and push each side of the front bar in while i guide the front bar into the plastic clips)
    Note: you will also need something to support the front bar while you do up the four bolts, as the bar will want to sag forward.
    jimbo
    missmcudd's Avatar
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by vn4play
    jimbo
    10 bucks is a bit steep for 1 that would nearly be stuffed
    Adam
    Jan 2006
    stanthorpe, qld
    do u mean this 1
    Adam
    vn4play Guest
    Yeah wreckers up here are charging like wounded bulls man!! always pays to check on new prices, i have been shocked many times at how cheap some bits can be new.
    Yeah that piece is the one, nice work adam
    VP Exec
    Jun 2005
    Replacements for the mushroom shaped lugs that get torn off the the body used to be available from Holden and may still be. They are fastened like a rivet.
    missmcudd's Avatar
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    how much you guys reckon it would cost to get someone to fix it for me?
    Jan 2006
    stanthorpe, qld
    wats broken?
    the bracket on the bumper or the car
    Adam
    VP WAGON V6
    Mar 2006
    i hae the same sorta problem with the wags.. the rear bar has come away at one side. The plastic clip is fine but the steal lugs have broken off. When i get some cash ill go find out if you can get those lugs from holden.
  15. #15
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by commy92
    just put 2 screws through the plastic into the metal!!!
    i will put pics up of how i did it in a min.
    Adam
  16. #16
    Jan 2006
    stanthorpe, qld
    here r the pics!! its easier to put screws in it to stop the plastic from jumping off the lugs when u go over a bump
    Adam
  17. #17
    Jan 2006
    stanthorpe, qld
    oops forgot to attach the pics here they r.
    p.s. there just short roofing screws. i just took the whole bumper off just to get 2 pics :my: and my parents say im lazy
    Adam
  18. #18
    VP WAGON V6
    Mar 2006
    so how do you take the rear bar off... is there bolts in the back somewhere??
  19. #19
    Jan 2006
    stanthorpe, qld
    first u have to take the reflectors out of the rear bar then there is a boltbehind each.
    then there is a bolt inside the spare wheel space.
    and under the car
    then it should just pull off.
    do u want pics?
    Adam
  20. #20
    pike Guest
  21. #21
    missmcudd's Avatar
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    so i gave up and im getting someone to do it. Thanks for the help guys this was just something i couldnt do alone
  1. My New babey girl!!!!!!
    By christian in forum VT - VX - VU - WH - V2
    Last Post: 28-11-2006, 01:04 AM
  2. the old girl(vn)
    By nathans1987 in forum VN - VP - VG - VQ
    Last Post: 01-02-2006, 02:20 AM
  3. the old girl
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-01-2006, 01:12 AM
  4. I Think The Old Girl Is F*cked...
    By unitdiplomacy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2004, 03:58 PM
