Results 1 to 2 of 2
Thread: How to: Install/ Remove gear select changer for auto trans
    vnberlwagon Guest
    Smile How to: Install/ Remove gear select changer for auto trans
    I changed gear selector today in my VN, old handle keeps on breaking, so changed whole thing to a VT set up. Quite easy to do about an hours work.
    Tools required: Medium sized phillips head s/driver, pop rivet gun, alum. rivets (4.8mm diam 9.6mm grip), 13mm ring spanner or 13mm socket&wrench.
    1. Remove centre console setup surrounding gear selector taking care to correctly remove gear selection plate(gear numbers&letters) easily snapped.
    2. Remove main body of centre console, screws located at bottom of console box, take care to unplug power window wires u/neath console as you don't get much slack in wiring, main wiring plugs are located at top end of console.
    3. Once console is removed drill out the 8 existing pop rivets, I used 5mm steel drill bit, don't use drill bit normally used for timber as they are not strong/sharp enough.
    4. Jack up car and place axle stands on both sides of vehicle behind front wheels. Slide under car with 13mm ring spanner or 13mm socket&wrench and undo nut holding selector arm and rod located behind transmission crossmember.
    5. You may have to work the old selector unit back & forth to remove it as it will have remnants of body deadener attached.
    6. Once old unit is out place new unit in and check that holes line up then climb back under car and re-attach selector arm and rod, then you can re-jack up car and remove axle stands.
    7. The reason I chose aluminium rivets over steel or stainless steel ones is that stainless steel rivets are extremely difficult to use unless you have a pneumatic(air) rivet gun, steel rivets are easier but rust, aluminium don't rust, are easier to use in a hand riveter and will do the job.
    8. Replacing the console is fairly straight forward just the reverse of removal. I haven't replaced mine yet as I am planning on painting it along with doing up the dash.
    I hope this will make the job easier for anybody planning to do the same, if there are any questions I will do my best to answer them correctly. Good luck
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    have u got a pic of it finished (dont care if center console isnt on)
    Adam
  1. help needed to remove vx gear stick please(auto)
    By wayvr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2008, 09:39 AM
  2. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  3. How to remove auto gear knob?
    By ascension24 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2007, 10:32 AM
  4. Whats the best to install auto trans cooler ?...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2006, 09:48 PM
  5. auto trans starts in second gear,no upshift to fourth
    By driver in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-11-2005, 07:04 AM
