Results 1 to 9 of 9
Thread: Vp Strut Location Or Control Arm?
    androo44 Guest
    Default Vp Strut Location Or Control Arm?
    Hi, I have just purchased a vp 1 exec and after completing a few little jobs on vehicle I noticed the left front wheel seemed to be closer the rear of the vehicle than the d/side. I ran a tape measure between front and back wheels and there is 20mm difference between the passenger side and drivers side.
    Looking at where the struts bolt up under bonnet, the nut "cap" is positioned differently as compared to that of the d/side. ie one is situated forward of the opening and the other is back of the opening, the opening being the big hole where the strut sits up to.
    Can these be turned around in 3 diff positions, and would this change position of the wheel or is it more likely the control arm is bent even though there is no sign of damage?
    Thanks in advance for reading.
    VP Executive R-spec
    Jan 2005
    The struts don't adjust the wheels forward and backwards, something is bent
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    have you checked your strut rod bushes at the front of the chassis??? they might be hammered and need replacing as this drags the front wheels alot further forwards than worn bushes do
    kirkson is offline Captain
    93 vr v6 exec duel fuel
    Oct 2005
    Yep, i'm with boona, also I had a similar problem on a vn a few years ago a wheel alignment fixed the problem
    regards kirk
    Captain
    VP WAGON V6
    Mar 2006
    easiest way is to get a wheel alignment, then they will tell you what is buggered.. that is if youcant work it out yourself.. lol
    androo44 Guest
    Smile
    Thanks to all posts, I had a closer look and found the end whre the ball joint sits was twisted backwards 15mm, obviously had a hit and bent that small area before the radius rod begins.. had to visually see it from underneath, Picked up another control arm today and all is fitted and good. Now measures same as drivers side. So off to wheel aligners later in week and get the final adjustment made.
    Thanks again.
    VN S1 V6 M5
    Aug 2005
    MaN|aC's Avatar
    MaN|aC is offline Donating Member
    VT 4.2 S/C
    Apr 2006
    take it for a wheel alignment, ask the person to have a good look underneath too see if anything is bent.
    *edit I didn't read the op last post...
    Another good tip is when buying second hand cars is too put your fingers in the wheel arch and count how many fingers that you can fit in both wheels if they are not the same its a good possibility something is bent.
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    Quote Originally Posted by getafix
    what does the position of the nuts do then?
    -dave
    it changes the castor.
  1. HdT VH SS VIN location
    By mytag5 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2007, 10:59 PM
  2. location of ECT sensor???
    By d_j in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2006, 04:19 PM
  3. iat sensor location
    By 9605wayne in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 05:35 PM
  4. IAT Sensor Location
    By S Pack in forum Electrical Wiring / Questions
    Last Post: 10-10-2005, 04:32 PM
  5. Location
    By jafo in forum General
    Last Post: 24-11-2003, 08:36 PM
