Results 1 to 3 of 3
Thread: Need info out of manual-ANYONE!
    simoVN88 Guest
    Question Need info out of manual-ANYONE!
    New to the site, Geelong Victoria.. anyone have access to a gregory's manual for a vn 88 exec? want to change wheel bearings, ball joins etc for roadworthy- if anyone has a scanner (and manual) please let me know either via the forum page or EMAIL ASAP. AM DESPERATE
    VZ SS 5.7 M6 Silver
    Mar 2005
    hey mate...has anyone responded?
    Wheel bearings are easy as..I will quickly explain now....
    Remove wheel
    Remove caliper
    Remove caliper bracket..
    remove front dust cap
    take off split pin (new bearings should come with new split pins
    remove nut, take note of the way the washer goes
    rotor should slide off now...
    take out old bearings and put new ones in, making sure you grease them up properly..
    fit everything back, and don't overtight the nut with the split pin, otherwise you will cook your bearings...
    Ball joints...don't have the manual with me at the moment, as I am at work...Haven't changed mine yet, but just take note of the way you remove them..Should be fairly easy...You might need a ball joint removal tool though...
    Hope this helps in the interim...
    VP WAGON V6
    Mar 2006
    what he said. Ball joint you just unbolt the bolt at the bottom there. get a set of popers, put it in and pop it out. simple as.. lol. they can be a REAL pain but. have fun with the hammer if you dont have a ball joint puller
  1. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  2. FS: VH Workshop manual and Owners manual
    By pro_gmh in forum Parts And Other Items For Sale
    Last Post: 27-09-2006, 10:36 PM
  3. Eaton M90 manual or installation info
    By vkberlina in forum General
    Last Post: 11-07-2006, 10:51 AM
  4. VN Calais 1990 manual ! Anyone with INFO?
    By Hot-Rod in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2006, 01:39 AM
  5. WTT: camira service manual for a VP sevice manual
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 01:18 PM
