Results 1 to 3 of 3
Thread: rem cable - audio
    ben k's Avatar
    ben k is offline ben
    VP Calais S2
    Aug 2005
    radelaide...bay area
    Default rem cable - audio
    ok currently installing sub/amp
    got it all in then wasn't working
    checked all wires for charge and wasn't geting any from the rem cable at the amp....just wondering where does the rem cable run to? back of the head unit im guessing?
    but yer couldn't see it so :S
    doing this as we type
    all help appreciated
    cheers
    ben
    **posted in audio as well but yer not much ppl in there and after answer asap. sorry
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    yes the remote cable runs from the head unit to the amp/s. it is needed to turn the amps on when the unit turns on. is the head unit a new unit and do you have the wiring diagrams?
    u can do a dodgy just to turn the amp on for a sec is to get a short wire from power and put it onto rem terminal just to test if amp works, not to sure if its bad for it ut i have done it a coupla times and havent had any probs, hope i helped
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    missus (in more ways than one)
    Sep 2005
    if you dont want to pull your dash apart to get the signal, and you are 100% sure you are getting power throuhg the main power cable, then run a new remote,
    What i mean is, underneith the sterering wheel, on the fuse box, fuse 13 is the radio fuse, hook a wire up to that (after the fuse), and run the wire into a switch (best place to mount the switch is on that drop down panel), now on the other side of the switch run a wire to the amp along the usual route (under kick panels etc.)
    Now what weve just done is create a nice police kill switch and also made a switch for the amp. so if you want it on always it will just turn on with the accesorise, but if you just want nice soft sound hit it, or if your crankin the subby and you see your friendly neighbourhood police man you can turn the sub off with the flick of a switch.
    hope that helps
  1. rem cable
    By ben k in forum Car Audio
    Last Post: 20-04-2006, 05:45 PM
  2. kick down cable
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-10-2005, 12:31 PM
  3. not quite audio but is used for audio purposes...
    By Tasmaniak in forum Car Audio
    Last Post: 11-08-2005, 02:50 PM
  4. Mystery Cable
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 10:30 PM
  5. VP kickdown cable
    By Namheul in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 04:47 PM
