Results 1 to 5 of 5
Thread: fuel filter
    R Photon's Avatar
    R Photon is offline I Like Bresciani Racing
    1990 VN Commodore
    Nov 2005
    Brisbane,Queensland
    Default fuel filter
    hey i changed my fuel filter in the weekend because i had a few problems..
    i just read that when you let your car run completely out of fuel (always happens to me) then put more fuel into your car all this crap from the bottom of the fuel tank gets taken through to fuel filter and clog's it up..
    so i was just wondering what kind of crap can be at the bottom of the fuel tank to be able to clog up the fuel filter?????
    i'm really curious
    Vz Sv6
    Jul 2005
    im not really sure exactly wat crap would be there but you REALLY shouldnt run your tank dry as this will kill your fuel pump very quickly as the parts in it need the fuel to lubrucate it.
    missus (in more ways than one)
    Sep 2005
    yeah dude, dont let your shit run dry, in an efi car that aint good by any means, fuel cannot always be dead clean, i.e it can be exposed to contamination by outside materials during the ocarse from productino to bowser, and this will usually settle at the bottom of your tank, but thats the least of youtr worries, and thats what the filter is for, like mentioned above, running the system dry takes away the lubrication and this kills things
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    When running the fuel low the pump would mostly pickup all the rust and crap from the holding tanks in the station.
    All stations would have rust in there holding tanks also water contamination could occur if the tanks are cracked which can send dirt/soil and other matter from the gound.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If you ran the tank dry to the point that the engine cut out, it might be a good idea to check out your catalytic converter. Nine times out of ten when an engine cuts out from lack of fuel it will backfire a bit, these shockwaves through the exhaust can destroy a cat fairly quickly.
    Gravity is proof that nature keeps getting us down.
  1. Vt Fuel Filter
    By cuckoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 09:51 PM
  2. Fuel Filter
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 09:06 AM
  3. Where is the Fuel Filter in VT
    By droodles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2005, 07:30 PM
  4. Vp fuel Filter
    By mc92ma83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2004, 07:39 PM
  5. Fuel Filter
    By beno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 08:46 PM
