Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: new manual in, still vibrates
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default new manual in, still vibrates
    hey guys, as most no i blew my reverse, i now have a new vr manual in that looks brand new for 600, it runs alot better but i still have a vibration, see with the old one and now this one wen i accelerate up and over 3.25tho rpm and seems to vibrate, now its not a knock knock sort of thing its harder i accelerate the hard and closer together the vibration is.
    but wen i put my clutch in to change gears it stops. but as soon as the next gears hits around that rpm level iyt does it again. so i think that crosses out warped flywheel or anything in that area, it cant be tranny and my ening was fine with the auto. so i think i may have my drive shaft around the wrong way??? but would it vibrate like that?
    it has a brand new clucth system and flywheel was fine in the old car. the only thing i wasnt 100% sure on was the postion of the drive shaft were it joins the diff
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    Apr 2005
    Is it located properly? Is it tight? Also, turn it 180 'n try it. If its still there, whats your centre bearing like?
    missus (in more ways than one)
    Sep 2005
    **** my car vibrates like a dildo when i give it to it, i thought it was the norm with these cars
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    greenfoam and i have been chating and have been crossing things out that it may be and isnt, so we were thinking is it possible that the clutch is warped? like maybe it came in the box already warpe as its brand new.. is that at all possible??? and wat should i do to check it, i mean i really dont wana pull it out again right now
    check my ride
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Did you get the clutch & flywheel balanced before putting it all in? Most of the time a new clutch will go in without a viberation hassle but you can get the odd one that will need balancing with the flywheel. Try indexing the clutch pressure plate around on the flywheel, sometimes this can rectify a balance issue. If this is a new gearbox it really cancels out the gear box, as for the tailshaft they generally only viberate under hard acceleration on take off. I tend to think it sounds like a clutch & flywheel balance issue. If you are going on the cruise on Saturday night i would gladly go for a run round the block with you and try and diagnose it for you as i am a mechanic.
    VZ SS 5.7 M6 Silver
    Mar 2005
    Hey guys...Off the beaten topic for as bit....I have a VN 5 spd manual calais, and it used to vibrate heaps too..Kinda like what is experiencing..And only under hard acceleration..I got the problem diagnosed when I went for a wheel balance, and it turned out to be the rear trailing arms...got them chanegd and its fine as now...Maybe have a look at them and see how bad the rubbers arm...Just my 2 cents
    Jun 2005
    Yes i have heard of that making a viberation, but he said it had no viberation before converting to manual, could not hurt to check them anyway. Cruzey is yours a factory manual calais?
    VZ SS 5.7 M6 Silver
    Mar 2005
    yeah mate.....Factory Manual....Not a bad car....mechanical nearly A1 at the moment..Am about to put a new power steering rack in, and then its Mech A1..Once thats in, will respray the car...
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    you have a missaligend spiggot barring remove
    gearbox a reinsert correctly you only need to remove by 3" and reinsert
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by vt1538
    Is the balancing different between the auto & manual like the Ecotec?
    yes the flywheel has a tdc so to speak
    Powered By Garrett
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    hmmm well it was never balanced, the clutch and flywheel that is, so i thinking it is that, but with the trailing arm mounts were should i look and wat should i chek for, any pics of the rubbers i gotta look at.
    so i guess im going to have to take it all out again but this time im getting some one to do it as i dont wana go through it all again, and im gonna have to wait till im working again, say my clutch and flywheel are out of balance would it hurt it if i keep driving for just a few more weeks.
    also yes ill be at the cruise so we can test spin it then, thanks.
    edit... as for burnz comment wat do u mean i have a missalined spigot bearing?? isnt that the sping that is in the crank? and how can it be misalined?
    check my ride
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    there is one more thing ive noticed aswell, in reverse it feels really odd, like ill be reversing and it sorta ticks, but a little harder almost a clunk, i odnt no if its got anything to do with my vibration.
    ill have to show u that too on the cruise vn calais 5.0, see wat u think it is.........
    check my ride
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    the spiggot bearing is a brass sleave whitch the input shaft of the gearbox
    lines up with,if not aligned cluch shudder is apperent
    Powered By Garrett
  15. #15
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok so i went to see manual tranny guys, they said to also check my engine mounts as one may have broken, hope thats it acctually
    check my ride
  16. #16
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok may have found it now, looking under my car again and noticed my pacemakers were touching the bellhousing, so i made abit of a gap, i think its better, well it does feel better but still there, think i need to take more of my bell housing
    check my ride
  17. #17
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Those engine mounts can really make your car seem like its rough.
    If you change them do both and start by lifting the engine up take off the left one and undo and replace the right one and then fit the left one last..the job will go a lot easier.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  18. #18
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    hey my pacemakers did that they rubbed on the bellhousing and the crossmember so check there as well just get out the ol grinder works a charm
  19. #19
    silver_bullet's Avatar
    silver_bullet is offline Now Genesis Blue Bullet
    vr commodore S
    Jul 2005
    moura
    maybe u wrecked the intrenals of ur drivetrain when u were doin stupid shit in reverse that caused it to blow ... dunno just an idea...
  20. #20
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok i guess ill have to go the angle grinder cause its not fixed 100% yet, ill have to check the cross member too, means i gotta take the extractors off, thats gay
    and silver_bullet im sure if i blew my driveline it would vibrate all the time and not just round 3 - 4 tho, well it does it all the time but worse then, and im sure wen i hit bumps it wouldnt stop and start vibrating
    check my ride
  21. #21
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    no need to take the extractors off vn-88 all i did was jack my car up on stands got under her and just looked for rubbing the grided too about 3-4 mm off the crossmember and a bit of rubbing on the bellhousing i think i even rubbed one bank of the extractors a little too
  22. #22
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i no exactly were there heading, and i made about a 2mm gap on the bell housing, but it aint enough, its better but still does itt, so ill have to take more off
    check my ride
  23. #23
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    well im un able to get to the spot on my bell housing cause of my extractors and cause i was still drunk from the night b4 found it to hard to get my pacey's off, so next weekend i guess
    check my ride
  24. #24
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    Quote Originally Posted by VN-88
    so its only vibrating up past 3000rpm and only when its in gear, did you put the cluthc in yourself? and did you tighten it evenley? so it was an auto before? so you put a new flywheel as well? is everything tight?
    cheers, nick
  25. #25
    VS II V6 Berlina
    Nov 2005
    when you put the clutch /box in did you replace the 2 little rubber bushes in the clutch fork that hold the release bearing in place??
    also in my vn I used to own it had a similar type thing happen. Found it to be the clutch fork vibrating on the bell housing itself (the little "window" the fork comes out of then connects to the cable. being a mechanic was able to put on hoist at work at grind the opening a bit wider with a die grinder. was all good after that.
  1. V6 auto vibrates in 3rd gear
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2010, 10:56 AM
  2. FS: VH Workshop manual and Owners manual
    By pro_gmh in forum Parts And Other Items For Sale
    Last Post: 27-09-2006, 10:36 PM
  3. vr vibrates after holden service
    By danflood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 12:11 PM
  4. WTT: camira service manual for a VP sevice manual
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 01:18 PM
  5. Steering Vibrates/Shakes
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 04:48 AM
