Results 1 to 19 of 19
Thread: Car not starting
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Default Car not starting
    hey guys my vp, when i drive around for a while and turn my car off. when i get to start it again it wont start me and my dad cant figure out the problem. we changed the fuel and oil filters rplaced the fuel and oil. We cant put our finger on it...can anyone help us out?
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    could be the crank angle sensor. Try pouring cold water over the CAS if it starts thats what it will be.(the crank angle sensor is behind the harmonic balancer on the right side.)
    Apr 2006
    has any one got a pic of this harmonic sensor?
    =Brock=
    My Ride
    spauldj308's Avatar
    spauldj308 is offline S Pack Man
    VR S sedan 5L, VSII ute
    Oct 2005
    Hobart, TAS
    The harmonic balancer is on the front of the engine, on the end of the crank. The fan belt runs around it. The crank angle sensor is near this. It has a wire running out of it.
    VR II S sedan - Genesis Blue - Cammed 304 - T5 - 19's - Weekend warrior
    VS II S ute - Diablo Red - V6 - Getrag - Daily Hack
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    the harmonic balancer is the biggest pully on the front of the motor. there is only one sensor behind it. on the right side looking at the front of the motor.
    Apr 2006
    how do we fix this, do we have to buy a new one or what
    =Brock=
    My Ride
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    first make sure it is the CAS. They mostly play up when the motor is hot so let it run to normal operating temp then turn it off and try to restart it if it wont start then pour cold water over the CAS if it then starts it is the crank angle sensor. If so you will have to buy a new CAS. then you have to pull the harmonic balancer off.(easiest way to undo the bolt is to put a breaker bar against the ground on the PASSANGER side then turn the motor over so it just cranks.) undo the CAS and install the new one. Then put the harmonic balancer and belt back on.
    Apr 2006
    if it is stuffed how much is this gonna cost me...
    =Brock=
    My Ride
    Vz Sv6
    Jul 2005
    $60 ish for the part and about the same again for the labour unless you do it yourself. i heard it can be fiddley if you do it yourself.
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Cant remember how much it cost me. i got one from Autobahn but it was less than 100 more than 50 i think. also get some thread locker aswell if you dont have any
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    could also be the battery, mine plays up when it is hot! it turns ova but very very slowly only when hot though! if it turns over like normal then i most probably the crank angle sensor or dfi module (coil pack).
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    Apr 2006
    ok well thx guys tonight im going crusing with my gf and tht so we'll see if it is the right angle sensor..i got some water in my boot to put on it if it dont start so we'll see...till next time guys lataz
    =Brock=
    My Ride
    Apr 2006
    hey everyone last night when i went crusing my car didnt start again twice so i put cold water on the right angle and it started straight away so we know what it is now...so what do we have to do do we have to replace it or can it be fixed or what ?
    =Brock=
    My Ride
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    you will have to replace it. Its fairly cheap and easy 2 do aslong as u can use a ratchet. I don't know how much a machanic would charge but it can't b that much since it only took me 30 mins at the most and im no machanic just a boilermaker.
  15. #15
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Quote Originally Posted by surfer dude
    Looks like problem solved to me eh?
  16. #16
    MT269U's Avatar
    MT269U is offline [LOLIFE]
    VS commodore
    Mar 2006
    sydney
    gday mate. i had the exact same problem with my VS. its jus one of those things that will go wrong with a commodore after time. i was pouring cold water over my crank sensor for weeks. eventually i got off my arse and had it fixed. it was only $200. and now it starts everytime. was urs cutting out while u were driving as well?
    Lowlife*
  17. #17
    VN s1 wagon
    Oct 2005
    Gold Coast
    its really easy to replace the only hard thing is the fact that it sits behind the harmonic balancer and u have to take the pully off so u need to be have an oversized ratchet or a rattle gun otherwise it can be a real ###cer to get off
  18. #18
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    im stuck.
    i have the gregorys book on the vn and i cant work out wat to do.
    can anyone help? please
    i was thinking of getten a mechanic to do it but i would rather save that money and get other sh!t done
    Adam
  19. #19
    vn88calais's Avatar
    vn88calais is offline Perth Representative
    VY Commodore 2002
    Jun 2005
    Perth, Western Australia
    yeah i got my crank angle replaced after my car stalling on me for every 8 days for about 3 months haha. but yeah 60 for part then 60 for labour, no problems now haha...took the mechanic about 20 mins or so, but he also changed my pads at the same time, got more discount too hahaha yer
    VY works currently in PRODUCTION!!
    Engine will still be sloow!!!!! ;-)
  1. Help Please Starting VS
    By obsessed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2007, 07:06 PM
  2. Still not starting
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:14 PM
  3. Just Starting out
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2006, 06:26 PM
  4. self starting car
    By SLugg in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-06-2006, 10:42 PM
  5. no starting sometimes
    By phoenix_blue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 01:33 PM
