Results 1 to 25 of 25
Thread: Steel rims 15x7 --do newer ones fit VP correctly?
    carzee Guest
    Default Steel rims 15x7 --do newer ones fit VP correctly?
    Here's a newb thinking aloud here ....I own a VP BT1 and would like to try the good ol' 15x7 chasers with 225s fitted. I have brought a fresh set off the govt car mob and they are on their way here to try. They said they will fit no worries. Freight is free for me so what the hell. The 16s are just such a hard ride and its so common -seems nowadays every car in the carpark has mags and super low profile tyres.
    Will they actually fit without a technical hassle? The stud pattern is a no brainer but is there a difference on where the guts of the wheel (I mean the middle bowl shaped stamped disc section with the wheel stud holes drilled in it) is welded?
    Were the VN-VP ones welded closer to the middle of the tyre? The wheel "track" would be larger on the VN-VP I suppose if the position was further into the middle of the tyre...
    VY SS Wagon
    Mar 2006
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    carzee Guest
    Hi, I'm a non-smoker. Given it up. Makes your clothes smell. Makes a lot of noise. Puts on points and puts up your premiums.
    I saw them there and the tyres are way too good. May have down 10,000km. Don't what they came off. I assume someone wrote off a near new car. The spare has never been fitted, not a mark on the stud holes.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Most will tell you that the offset of a VP with IRS is different to every other model commodore, and you'll even get some wreckers selling cop rims 'only for VPs with IRS', but thats a load of bull. I've used many different cop rims of various model, and all of my mags fit the same across the 4 different cars i've had (VK, 2 VLs and a VP).
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    foammedia Guest
    Well standard later model commodore offset 8 inch mags don't fit on my VP with IRS, they rub the paint off the inner gaurds, ceptors will work but only because they are skinny, but I bet the original stock wheels on the IRS VP were a different offset because the car looks silly skinny with the normal ones ok now I'm going to retire again
    carzee Guest
    just got under and looked. Its definitely the standard rear end. Lots of sway bars.
    I'll put 'em on soon as.
    VN Berlina V6
    Mar 2005
    carzee Guest
    ok....I just put on the 15x7s and went to the servo to set up the air pressures. Much improved on the ride, its not as hard a ride as it was thats for sure.
    The tyres I took off were 16in and side by side on the cement the chaser 225x15 steel wheels stand 1in taller, so thats half an inch extra on the radius from the previous PCW wheels. Maybe it won't scrape the speed bumps now.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If you've changed tyre size like that, how much is your speedo out now?
    Gravity is proof that nature keeps getting us down.
    carzee Guest
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    each to their own I guess. Your car still looks hot, but I prefer mags (not necessarily the ones you had on there though).
    Have a look here for speedo difference:
    http://www.miata.net/garage/tirecalc.html
    mouce's Avatar
    Jul 2005
    The only thing I'm not a fan of with those rims are the marks where some previous owner has had hubcaps on there. A good clean and a respray will solve that. Otherwise, I reckon it's come up okay.
    carzee Guest
    Yeah, they need a rub with cut n polish at least. When I get time..
    I tried the tyre calculator. It comes down to whether they are 225-60R-15 (incorrect speedo +4.6%) or 225-55R-15 (matches 205-65-14 speedo)... will check when it eases up raining.
    ''''''''''''''''''ends up being 225-60R-15 (incorrect speedo +4.6%)
  15. #15
    VY SS
    May 2005
    SA
    I reckon the 15x7s look mint on your VP mate, havin the 225s definatley sets it off! Definatley looks tough, and suits it being a BT1. The VP looks in bloody good condition too!
    Cheers, Gaz
  16. #16
    carzee Guest
    Went to the drive-in tonight. Rode nicer. The wheels look big! Every other commy had chrome mags etc, mine was different.
  17. #17
    VN Berlina V6
    Mar 2005
    Hello ? - where did you buy them off the government mob and how much did you pay etc ?
  18. #18
    carzee Guest
    Quote Originally Posted by DF_Media
    I got the five complete rims, caps, nuts, almost new Bridgey 225s for $500 cash. They have "Sorry no EFTPOS" there.
    The outfit advertized in the TradingPost.com.au and are a licensed car yard in Parramatta Road Sydeny. I forget the name.
  19. #19
    carzee Guest
    Just looked it up:
    Commodore 2003-2005 VYII/VZ Ex Chasers, 15in steel wheels. Over 25 sets to choose from, from $100 a set to $400, DL-16146, 131A Parramatta Road HOMEBUSH 02-9746 7933 or 0411-224677 ah.
    ...and there was another ad too:
    Holden Factory Alloys/Chasers Alloys brand new Statesman, Calais, S-Pack, SS, Equipe, Berlina and Vectra/Astra, all at greatly reduced prices starting from $75, Chasers 15 x 7 and new 225/60/15 or 215/60/15 $550 set of 4 including caps and nuts. Holden factory wheels, 16in factory alloys with tyres from $650. Claremont Wheelpower BANKSTOWN 02-9793 3155.
  20. #20
    carzee Guest
    I just found Tufparts Melbourne is selling a set of 4 rims (15x7) with caps and nuts -all NEW parts. Unmarked. On feeBay.
    No tyres included.
    http://cgi.ebay.com.au/ws/eBayISAPI....tem=8059401612
    So far the bid is $87, which compared the price for caps and nuts alone, is a good buy to say the least. [This mob sells elsewhere on ebay a set of 4 centre caps and nuts for $70 on their own.]
    Freight kills it a bit for anyone interstate though.
    But if you're living in Melbourne/Geelong/areas and can pick up... wow.
  21. #21
    Mr Squiggle's Avatar
    Mr Squiggle is offline Banned
    Rocket
    Apr 2006
    Dude can you put the picture of the VP up again with the original mags because that was the only picture I've ever seen of a VP that still have the silver on the door/window trims
  22. #22
    VN Berlina V6
    Mar 2005
  23. #23
    carzee Guest
    Quote Originally Posted by Mr Squiggle
    http://www.mygraphix.com/index/pic.php?u=9F7PTT&i=100
  24. #24
    VN Berlina V6
    Mar 2005
    Spoke to the dude at :
    The 225's are Sumatomo - the guy seems to think they are great tyres.
    Asked him about the difference between the 205/65/15 and the 225/60/15 he said only a few mm's in it - if you do the maths its 133.25mm verse 135mm.
  25. #25
    carzee Guest
    Well, I wanted the 225s or at least 215s. 205/65 is just stock as they come -its a taxi tyre... maybe you meant to type 215.
    That ebay auction in melbourne finished about 6pm last night. The 4 rims & centers sold for $167... Thats about 40 each for factory new --then you gotto freight them - if you don't live in Melb that is.
    Doing the math, bankstown deal looks alright. A 225/60/15 costs about $150 on special at KMart I think.
  1. WTB: Steel Rims
    By gslrallysport in forum Swap / Wanted to Buy / Trade
    Last Post: 02-10-2007, 12:27 PM
  2. 15" 37p steel commodore rims
    By jcorser in forum Swap / Wanted to Buy / Trade
    Last Post: 08-02-2007, 05:55 PM
  3. Speedo Not Reading Correctly
    By driscolld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2006, 03:57 PM
  4. 15x7 'ceptors
    By AirStrike in forum General
    Last Post: 19-10-2004, 10:22 PM
