i have been told that vn injectors are the same with v8 and v6.. going by this site i am lead to believe that my injectors are 195 cc's i thought they were only 160 or something.. 0-280-150-901 is the numbers on my injectors. is this site right.. http://users.erols.com/srweiss/tableifc.htm
also does anyone know what cars have bigger injectors that will fit my vn v6..
thats the part number for V6 & V8 injectors.
Theres no need for bigger injectors unless you are going to forced induction, the std ones are fine.
You will need to re write the memcal to suit if you change the injector flow rate.
Rob
i am going forced induction. and i did know i have to get my memcal re-written. just gott find a place in either adelaide or melbourne to do it.. anyone know of anywhere good...
is that web site rigth about vn injectors being 195 cc's
the memcal bit is easy to look after, but if youre going boosted you will need a full re-program anyway.
Not sre on the flow rates in cc's but the best injectors for you will be V6 supercharged ones, they are 36lb, std is 18 stroker (blue top) are 24lbfrom memory
Rob
here ya go budy try these ones , lots there at a cheap priceOriginally Posted by defa
http://www.tuffcarparts.com/store/index.php?cat_id=25&catname='E.F.I%20Fuel%20Inject ors'
Cheers.![]()
* RVN 355 *
thanks mate.. will have a look at it now..
