Results 1 to 6 of 6
Thread: Help on installing a Fuel Regulator please.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Default Help on installing a Fuel Regulator please.
    I got my Fuel Reg today, Went out to the car and stopped, Was wanting a touch of help, As it sits at the back of the fuel rails do i need to remove the rails and injectors to remove the fuel regulator?.
    Or i noticed at the back there is a nut where the regulator goes if i remove that will the fuel regulator just come off easy?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    vn hsv sv 89
    Apr 2006
    From memory there is an allen key bolt on the back that is all you need to undo.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    beauty mate thanks
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    well i think i know what you talking about and it sis on the drivers side of the engine bay and had a vacuum like connected to the inlet manifold, well if this is it, then mine on my VN has 2 bolts that holds it to the fuel rail and then it sits in there with an o-ring (i think) cant remember for sure, memory not crash hot, hopes this helps a bit
    vn hsv sv 89
    Apr 2006
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Thanks for all the help guys, And thank Sik sv you were spot on with the Allen key bolt once that was off it was hard to get the fingers in there to get it out, Once out it was even harder getting it back in, But all is done no leaks which is good.
    Now I'll just sit back and wait and see if the fuel consumption gets better, If not next on the list is the oxygen sensor.
  1. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  2. Fuel Regulator
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2006, 10:37 PM
  3. fuel regulator
    By chunderlicious in forum V6 Development And Modification
    Last Post: 18-06-2006, 06:23 PM
  4. fuel regulator
    By houseing in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 05:30 PM
  5. WTB Fuel Regulator
    By PhatVN in forum Swap / Wanted to Buy / Trade
    Last Post: 14-10-2005, 04:46 PM
