Last night i was driving along the freeway and everything is fine. I had a wierd smell then no more heat and my temperature gauge sat on the very bottom line.
I am hoping it is just the thermostat is stuck open. What do you guys think?
Sounds more like a major coolant leak.If there is no coolant on the sensor it will read zero.
even after driving there was no heat coming out from under the bonnet. Just checked and the radiator is full and the resivour is empty.
If your coolant level is fine, yes a stuck thermostat can cause the car to run cool. It was your description of a funny smell, no heat at the vents & the quick drop of the temp guage that makes me think it was a hose failure.
hrrm wierd one check your oil as well or just go to repco and get a new thermostat its around 18 bucks i think i replaced mine a few weeks back as i had no temprature reading at all now its fine .
Was your car driving fine after the loss of heat or was it sluggish at all
mine always and always has read just above the bottom line on the highway. The more i rape it the the cooler she gets.
she actually drove heaps better. And tonight while i was driving around the burbs in traffic everything was just fine.
mine runs just above the first bottom line, i was sorta worried about it running that cool, in most cars the temp needle runs round half way but the vns could just have a different set up, but with ur problem bud i dunno, when u get home park it on paper or anything just to make sure nothing is dripping out or something like that, the smell could be leaking water into something hot or even flying back onto the extractors or somethign, justhave a look round engine bay for coolent splatta or somethign...
mine sits 1 line before the hot is that alrite![]()
Adam
lol are u serious??
yes. its been about there since i got it. but i still need to flush the radiator and block. who knows when that was done lastOriginally Posted by commy92
Adam
I think Adam should get it seen to ASAP
yea thats not normal!!!!
VS SS - Street/Show Project [BEEFY]
http://forums.justcommodores.com.au/...-beefy-v2.htmlHID Kits from $100 - Installation available PM FOR DETAILS
its not fairOriginally Posted by beefcream
i will get them to have a look at it when i get my o2 sensor and crank angle sensor put in and get my tranny looked at
Adam
Sounds very much like the thermostat is wide open (need a new one). The car would be 'running better' Because engine management will be giving it more fuel to try and warm up. The result is a bit more power, but crap economy.
As for the smell, the air ducts behind the dash give of funny smells everytime the temperature of the air running through them changes enough. (like when you turn off the AC but leave the fan going.
