Results 1 to 7 of 7
Thread: Giving TB a good clean
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    Default Giving TB a good clean
    i want to give my TB a real good clean.just wondering if i take of the part coming from the engine or the part my intake pipe goes into or both. its a series I. And does anyone know how many nuts there are on each piece as i am limited with tools and do not having a socket set. I dont want to find i need to remove a nut i cant reach easily after getting the others off.
    cheers
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    2 13 mm nuts and a gasket, disconnect the accelerator cable and kickdown cable if its an auto, disconnect the throttle position switch, the idle air cotrol and the egr valve that joins onto your rocker cover, oh and your vacuum lines on the side of the T/B
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    You only need to remove the intake pipe, then undo two bolts (maybe one bolt one nut) that hold the t/b onto the elbow running into the manifold. Disconnect all the hoses and electricals from the t/b and unhook the cable(s) from the accelerator (and auto if it applies).
    You should now have the t/b in your hands. Be VERY careful taking it off, the gasket is just a shitty little paper thing and tears very easily.
    Gravity is proof that nature keeps getting us down.
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    thanks you make it sound way too easy do you reckon ill get it off with a small wrench or am i going to have to find a socket wrench as from wat i can see its a tight area near the injector /fuel rail
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    Attempted to remove TB today and had no luck. Took the Kickdown cable off and encountered 1st prob. The springs are really rooted and the metal washer is cracked. Now prob 2......got my mini shifter and the top nut is too close to the windscreen plastic thingy and bonnet bay so i cant undo. The bottom nut has the fuel/injector rail in the way. Both nuts are not accessable with the shifter or even with a wrench with the ring end. It seems i will have this problem even with a socket wrench with the right angle thingy as there is little room.
    Does anyone else have this prob or is there a different tool to use.
    mouce's Avatar
    Jul 2005
    I just used a socket on the end of an 8" extension bar with a ratchet on the end. Works a treat.
  1. the old man is giving me his vn wagon
    By shane.MC/VT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 01:23 PM
  2. carbon clean/injector clean
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2006, 10:24 PM
  3. Giving me the shits!
    By collovlcommy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-08-2005, 06:50 PM
  4. VX giving rev between gear changes
    By Vx-er in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 07:37 PM
  5. Thanks Giving
    By Darren in forum Jokes/Humour
    Last Post: 26-10-2003, 09:12 PM
