hey guys, got my new vr t5, for my vn, but ive noticed with this one and my old one wen my car is cold and the tranny is cold, its hard to shift down wen slowing down and crunches alittle wen changing up, mostly aorund 1 - 2 - 3.
i suspect the oil im using is maybe alitttle think and cant warm up fast enough, the sincros should be fine. it had a re build not so long ago, so wats the best oil for my beloved t5, money is not an issue.
also is it possible to have gauge to measure my tranny oil temp, so i no wen its warm and wen i can start to give it to here and back off alittle??
i got a vn t5 pretyy sure they're the same and i've been told by mechanics to actually run dexron 3 through it
dexron 3? wat sort of oil is that? ill have to try it, cause im sick of having trouble shifting wen cold
noooo.... i wouldnt listen to that. dexron 3 in not oil its auto trans fluid. u may be able to run it but i wouldnt. Get you owners manual out and read what it recommends.
aint got one for my manual
so i need to no wat everyone elses says
i use dextron 3 in mine and it shifts fine in all conditions.
kilowatts are like drugs, the more you get, the more you want.
ive got some other stuff, abit more expensive, i was gona get shit work 26 for 1 litre but didnt have enough till next week, this stuff was 33 for 4 instead of the other which was 25 for 4, its a white drum thing, and its like 80 something with a black label
all ford manuals run dextronII
most manuals are happy on auto oil.
espeshally good for 1/4mile
lite fast gear change
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
Yeah any auto trans fluid such as dexron 3 will be fine for it
ok i stand corrected...
I would get the stuff that is mentioned in the manual just to be on the safe side
well this stuff i got is excelent, heaps better now
ok the gregories manual tells u to use shell gear oil XGO 75/90
this is for the borg warner t5 manual transmission and it takes 2.05 litres
What Dezza said.
I've seen the after effects of running trans fluid in a gearbox, everything melts, and the oil is too thin to lubricate the cogs properly. You can all post saying its bullshit, but if you don't want to be hunting around for 'another' T5, then i suggest you drain it completely and put the shell stuff in.
Originally Posted by davway
mate i know of a vn thats used it for 318,000 kays and it still shifts fine.
That maybe so. but gearboxes aren't cheap, his best bet is to use what holden say!Originally Posted by str8up
have a look at any dextron III bottle, it says for use in Automatic transmissions, and power steering, nothing about gearboxes
Like i said, go for it if you want to, but if you do, please don't post a 'my gearbox is blown' thread in a few weeks.
as i said b4 most late model fords run on dexIIOriginally Posted by STEALTHY
Powered By Garrett
burnz - who gives a crap what ford use in their gearboxes - it's a T5 for a commodore. you don't use dex III in a T5 box. only the 6 speeds have dex III in them and even then they are a "fill for life" box (means not need to drain and refil). in the T5 you would put mobil XHP oil in it. Before you say anything - yes it's engine oil and it quite ok to run in a T5 - I used it in my T5 and never any drama's.
i believe burnz said dexron II (2), and also arent the T5's in ford as well? isnt it like a borgwarner box or something? so they are basically the same for ford and holden
ok, he can run what he wants, just thought i'd try and save a guy a few 1000 when his box melts.
the fords may have a T5, but there are differences, i don't see the issue, run in it what holden say, after all, they had the box made in the first place.
well ill just say ford box and holden box only difference is gear ratio, but they hav a different bellhousing and bolt up spot, but who cares, and this oil i have is the best ever, runs smooth and fast now. cause its thin it warms fast and doesnt get to hot. so ill stick with it, plus i change oil every 10 to 15 thousand k's in everything so this oil was best.
thats alright, what sort of oil are you using in yours? im only using just some cheap gearbox oil,
cheers, nick
Shell Synthetic Gear Oil.......
use the dextron 111 i run it on my vs clubsport with t5 gearbox and that`s what the holden dealers recomend also never had a problem with mine for 3 years and i do give it a hard time also
