Results 1 to 16 of 16
Thread: My car is a never ending problem!!
    Vz Sv6
    Jul 2005
    Angry My car is a never ending problem!!
    Hey all,
    i would like to tell you all about my car and the recent problems it has been having.
    first the Crank angle sensor dies and needs replacing so that gets done, then i get one of greenfoams memcals and have some fun with that but sure enuff about a month later my CAS is playing up, so straight to the mechanics to replace it. next day driving the car it stalls, check codes gives me 33 (i think) which is the map sensor, so i replace it. I decide then to change the oil as i was running low as im losing oil :b: so i change the oil and decide to flush the raditator as well and put a new themostat in.
    get it all done. Go on holidays over easter (without my car)
    come back, drive my car and find out its leaking some coolant from the themostat housing, so i tightened it a little more ( not much as thats how i broke the old one!!) after that it still decides to leak a little!!!
    next thing to happen is another code 33!!!! :b: ::b: and a code 13! ( oxygen sensor was replaced in jan this year). i decide to put my stock memcal in and get my caar running A1. 2nite im on my way to the shops and i get code 45! (oxygen sensor) so now im just sick of my car! on top of all this my car is leaking oil from somewhere that i have yet to get check out.
    Now the question is, Could there be some dodgy wire/s that are causing all these error codes?
    Thank you for taking to read my rant!
    p.s. also my car is looking worse everyday as my paint is fading VERY fast! damn oxidation
    missus (in more ways than one)
    Sep 2005
    mite be a faulty ecu, i duno, but by the sounds of it your car is chewin through sensors, get some opininos from a few good mechanics/ auto elecs, and remember , the computers are only like 40 bucks
    Vz Sv6
    Jul 2005
    Quote Originally Posted by CSL
    forgot to mention, put a new ecu and memcal in today as my soldering skills with greenfoams memcal werent the best!
    My00 Wrx 240kwatw
    Apr 2005
    did you put the little O ring rubber seal with the thermostat? if thats in good condition there shouldnt be any other reason for leaks..
    Vz Sv6
    Jul 2005
    Quote Originally Posted by VNPOWER
    i did the first time, but the housing broke and when i checked the themostat the o-ring had crumbled in half. i just left it off, it seemed to fit better with out the o-ring and i had the gasket for the themostat housing.
    since i have been running the stock memcal the car has seemed to be heating up LOTS! the gauge goes to about half with a 15min car drive, i thought the radiator was surpose to stay cool and the engine warm?
    i also got code 45 today!
    so im booking the car to go to the mechanics on tuesday to get it looked at.
    my mechanic skills are going to be put to rest once my car is running A1 and if i have any problems it will just go to the mechanics. i just want a reliable car.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    The mystery oil leak: If it's at the back of the engine and dripping onto the drive way? Well...sounds like a rear main seal. Join the club mate. Almost EVERY VN out there has a bit of a leak from the rear main.
    Gravity is proof that nature keeps getting us down.
    vn88calais's Avatar
    vn88calais is offline Perth Representative
    VY Commodore 2002
    Jun 2005
    Perth, Western Australia
    Quote Originally Posted by mouce
    boy oh boy do i know that one, but mines fixed, hopefully it wont happen for another couple of years again yay!!
    Quote Originally Posted by fully
    i know the feeling...
    hope the issues get cleared up dude
    cheers, Todd
    VY works currently in PRODUCTION!!
    Engine will still be sloow!!!!! ;-)
    foammedia Guest
    You can buy my VN if you want , before it goes rusty on the front lawn, it's got faded paint too but hasn't shown an engine light for a couple years now. It's getting pretty old though so I don't want to even look at it sideways or it might break. I'm having enough troubles getting the VP right without worrying about two cars. I had a new CAS put in the VN about 2 years ago and changed the thermostat and some hoses a few months ago because it was crusssssssty
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    CAS crank angle sensor? Where about is that and how do you know that is going or gone?. Curious.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    foammedia Guest
    It's behind the harmonic balancer. Mine wasn't broken, just got it changed because the car had done enough ks that it could have gone at any time. The harmonic balancer let go soon afterwards anyway so might aswell have waited for that
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Are they both cheap to change cause I'm over 300,000km and i think it might not have much life left unless I'm wrong and panicking
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    yep been there,
    also had a dead ecu... it told me my oxy sensor, and crack angle were dead
    Vz Sv6
    Jul 2005
    well atm my car has been traveling pretty well, oil leak was fixed ( timing cover seal $150) and ecu was replaced. only thing is it feels like a slug cus i took out foamys chip as i was using too much petrol! i just need to give my tb a clean as it is idling kinda average. oh and i just put my 6x9 in!
    cheeers
    foammedia Guest
    But the chip was just stock with a bit more timing, it can't use more fuel unless your foot was heavier , just thinking, maybe I sent you two? if I did try the less radical one
  15. #15
    Vz Sv6
    Jul 2005
    yeah i think it was my foot, it was so fun! i only tried one didnt get around to using the RF chip? or watever it was. but it diffinatly did give me some gains. i want to get my car running A1 before i put the chip back in. btw i was getting on average 15-18 ltrs per 100kms :/
    cheers for the chip though
  16. #16
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Quote Originally Posted by foammedia
    hey yea mine is ****ed too, do u kno how much it costs to get replaced, mine shits its self after i cruise around for a long time with mates. damn thing wont start, i gotta tip some water over it and bam starts up with ease.
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
  1. Never Ending Rim Search
    By kipela in forum General
    Last Post: 18-08-2006, 05:16 PM
  2. Never Ending Rim Search
    By kipela in forum General Discussion
    Last Post: 16-08-2006, 09:57 PM
  3. Replies: 18
    Last Post: 18-02-2006, 10:16 PM
  4. Never ending Drama....NEONS!
    By raZel in forum General
    Last Post: 17-08-2005, 04:37 PM
  5. leaks from front ending on floor
    By jimrichards1964 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-06-2005, 09:37 PM
