Results 1 to 3 of 3
Thread: tacho wire
    VN Commodore
    Feb 2006
    Default tacho wire
    can anyone tell me where i can get a tacho signal from on a vn v6. i don't want it for a tacho i want it for an additional injector controller.. it reqires a tacho signal..i spose you can tap into the back of the dash but i was told there is a better spot under the bonnet somewhere.. if anyone can help let me know..
    Reggie Guest
    Smile
    The taco signal wire for a vn v6 commodore is on the passenger side engine bay. There is a wiring harness there which if you look closely there is a white plug on a brown wire all by it's self. you may need to peel back some of the black tape, that will give you a signal.
    VN Commodore
    Feb 2006
    thanks buddy. i will have a look tomorrow
  1. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  2. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  3. help needed which wire is tacho illumination
    By canb_vn06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2006, 12:42 PM
  4. orange wire and orange white trace wire - which is "+", which is "-"
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 09:28 PM
  5. Tacho Wire
    By wes in forum Electrical Wiring / Questions
    Last Post: 12-01-2006, 09:42 PM
