Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: How to put a tacho on vn
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default How to put a tacho on vn
    hey i was wondering how i put a tacho on my vn commodore. do i have to run a wire through the dash. where does the wire go. is it hard to fit one? cheers
    VYI equipe sedan and vyII acclaim wagon
    Jan 2006
    adelaide
    Apr 2006
    canberra
    what about those tachos you stick on your dash. is it posible to fit one of them on?
    gocommygo Guest
    step one, go to a place that sells tachos, step two buy it, step 3 put it in your car and try not let it fall over
    Jun 2005
    since its an executive, dont you have a tacho in it already?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Reggie Guest
    Smile
    ok...... you will have prob three wires coming out of the taco... one will go to ground(earth) the others will be for accesories and signal wire. the signal wire will run to a brown wire on the passenger side of the engine there's a loom there which has a small white plug hanging out...on the end of the plug will be a brown wire by it's self. that will give you signal.
    make sure the taco is on the correct setting or you will be doing 8000rpm changes.,.hahaha
    Apr 2006
    canberra
    ok thanks. how do i get the wire through the dash? will i have to take out the dash or something? what side is it better on. the side right hand side of the steering wheel or the left? and na my car doesnt already have a tacho for some reason.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    NOTE: The wire colors might not be the same on all Tachs.
    Its pretty straight-forward installation but as for the Green Wire (refered to diagram) can be connected to the signal wire found next to the Right Strut Tower (looking at front of car) in the Engine Bay (White Connector and Brown Wire, which may be hidden under some tape). Run a new wire from the connector back through the Firewall to Tacho.
    Hope That Helped
    Jun 2005
    i say go for a level 2 or 3 dash instead
    Apr 2006
    canberra
    where can i get a level 2 or 3 dash from. how much and are they hard to install?
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Go for a Level 2, that way you don't have to rewire ANYTHING. All you need to do is remove the old cluster and put the new one in. So long as you know which end of a screwdriver to hold on to you're set.
    Check out wreckers for a Level 2 cluster.
    Gravity is proof that nature keeps getting us down.
    Calais V
    Jan 2006
    if you use a Level 2 Cluster, does the original wiring harnes and connector in dash(VN series 1 with no tacho) have the wire for the tacho ready?
    or still need to run the single wire from engine bay as described earlier ?
    any idea what prices are Level 2 Clusters ?
    thanks
    Jun 2005
    yep the wiring is all there for level 2. only need to modify the wiring for a level 3
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    I just had a look.. and there's no wire (I can see) that fits the description under the bonnet.. possible for a picture to be taken?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
  15. #15
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    it might be in a different place in a VR. i was referring to a VN/VP. i will try to get around to taking a picture later on if no-one has taken one.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  16. #16
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    sorry for the wait... and engine bay needs a clean lol
    its the little white connector (i forgot to put a circle around it)
    My (ex)Ride
  17. #17
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by tr3nt
    Passenger side strut tower trent. Mine was taped behind the tower. Its a solid brown wire (no trace).
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
  18. #18
    vs statesman
    May 2005
    hey i just lookd to and found the wire but i got a few tacho's floating round but they wont register a signal off that wire??? can anyone help??
  19. #19
    93 Series II V9 Executive 3.8L Supercharged 11Psi
    May 2005
    yeah, the signal will be around .5 to 1.5volts, it sucks, it means you need a GM Coil Pack converter, i bought a really small 2 inch tacho and had it nicely housed on the dash, ( I HATE RICEY TACHOS! ) and it didnt work cause it wasnt a 12v signal.
    instead of ****in around with a extra GM part, i just gave up.
    #### the ####ing ####ers!
  20. #20
    My00 Wrx 240kwatw
    Apr 2005
    Quote Originally Posted by tweakt
    yea you can join me and the rest of the people who couldnt get a tacho working on that wire not to mention 3 other wires that also had a singal. I gave up and got a level 2 dash.
  21. #21
    hispeedvp's Avatar
    hispeedvp is offline VP SS Ute
    VP Group A Ute
    Jul 2005
    W.A
    so is there anyware to get a signal for a 4" tacho? if not whats the convertor thing?
    [SIGPIC][/SIGPIC]My New Engine, A Work In Progress
  22. #22
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    there is an artical i found in a street machine magazine that you can hook your tacho straight up to the wire in the engine bay (vn) without an adaptor. i can scan it and post it up if any1 wants a look at it. its called "tach tech".
    My (ex)Ride
  23. #23
    Apr 2006
    canberra
  24. #24
    My00 Wrx 240kwatw
    Apr 2005
  25. #25
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    if its too small to read. save it to your desktop (or wherever) and open it with the "windows picture and fax viewer" (should be default application and open when when you click on a picture) and zoom in on it.
    i have marked out the paragraph in red. (pretty obvious lol)
    ^^Article Taken From Street Machine Magazine^^
    My (ex)Ride
LinkBacks (?)
  1. 18-12-2009, 10:27 PM
  1. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  2. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  3. tacho
    By blue vn in forum Electrical Wiring / Questions
    Last Post: 19-11-2007, 01:08 PM
  4. tacho
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2006, 08:50 PM
