Results 1 to 12 of 12
Thread: Minor crash, right wheel = screwed, advice please..
    sbkvp Guest
    Default Minor crash, right wheel = screwed, advice please..
    Hey guys,
    Unfortunatley I had a bit of an accident today, bloody rain and slippery roads. Nothing major thankfully, but I hit a median strip and my front right wheel has been smashed right back, so much so that its more or less sitting on the mudflap. My left wheel is fine.
    I've had it towed to a mechanics but I'm just wondering if anyone can give me a ballpark guess as to what's screwed and how much $ I'm going to have to fork out.
    Thanks in advance.
    PS No pictures, sorry.
    '00 WH V6
    Dec 2005
    Well you've probably got a bent axel if that's happened.. hopefully nothing more than that.
    No idea on costs..
    Driving a CURSED WH V6.
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    yeah i did a similar thing in my VN, bent my rim back and bent the axle, so my right back wheel was on so much of angle that when i drive home it scrubbed the crap out of tyre, it cost me $50 for an axle, and i got some new bearings, cant remember price and put it all in myself, but yeah if you took it to a mechanic you could be look at a few more dollars, plus what ever other damamge you have done.
    cheers, nick
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Depends, is it your front wheel or your back?
    Gravity is proof that nature keeps getting us down.
    '00 WH V6
    Dec 2005
    thats a good point... lol... i was just assuming rear..
    sbkvp Guest
    Sorry guys.. Front wheel. The two rears and the front left are fine, thankfully.
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    you might be up for a fair whack if you've done considerable damage to your front suspention.
    if this is the case take the oppertunity (depending on funds) to upgrade your front end.......
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    im guessing:
    **New Upper and Lower Control arms
    **Hole new strut tower (plus springs and shocks)
    **New sway bar
    **Porbably new power steering boots (maybe two depending on how far its impacted..they rip so easy)
    **new wheel
    **Paneal beating work on your strut mounts, cos they'll be bent im guessing.
    ** maybe a few other things......
    Id say $600+ mate....could be worse or better but id say an absolute minimum of $600.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    my friend did the exact same thing today except on the passanger side
    damage was k-frame slightly bent, z-arm bent, lower control arm bent....
    $50 for parts - about a day's work.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Cost me $175inc labour to get mine fixd, new stub axel, lower control arm, z-bar, k-frame.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    mouce's Avatar
    Jul 2005
    Quote Originally Posted by azkwazere
    im guessing:
    **New sway bar
    **new wheel
    aZk.
    The panel beating of the strut tower mounts is a good point, if you've hit it hard enough to get the front wheel to almost touch the mudflap, chances are that you've bent the mounting for the tower. That's going to cost a mint to get done (unless you've got a mate who is a panel beater).
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    i hit mine hard enough to put the wheel into the inner guard/mudflap, no strut damage.
    cheers
    mat
  1. VR TO VS Front Wheel Bearings Advice
    By kowan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2011, 09:10 PM
  2. Did I get screwed?
    By Holdens Rule in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2007, 11:25 PM
  3. Screwed up weather
    By VS Omega in forum The Pub
    Last Post: 16-11-2006, 11:22 AM
  4. Diff screwed
    By Shounak in forum General
    Last Post: 30-05-2006, 06:04 PM
  5. VR BT1 speedo screwed
    By HoLDenGuY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 12:13 AM
