Results 1 to 11 of 11
Thread: Electric Window drivers side prob
    VN SS 5ltr
    Jan 2006
    Wagga
    Question Electric Window drivers side prob
    Window went up and down fine then slowly it would struggle now its dead, when u click the button u can hear the motor kick in to let the window down but as for going up its got nothing.
    Does anyone think this could be a switch prob?
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    If you can hear the motor i doubt its a switch problem, check the runners and mechanism itself, mine run a little slow, but i think its the runners in mine
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    i have the same problem on the right hand passenger side.. one day it went down and up then stopped half way.. i kept pressing it and i got it up but now it doent move at all.. i can hear like a slite noise wen i press the button so i tink mines the exact same problem.. i dunno all other windows waork 100%
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    VN SS 5ltr
    Jan 2006
    Wagga
    Quote Originally Posted by Keesh
    My right rear passenger window never worked when i got the car and it cost shitloads to fix it, but dont think it has the same prob as my drivers side. My problem is i gotta find time to check it out.. becuz the window is down and its left outside, however there is a roof over the top.. thank god because its rain'd all day
    Keesh's Avatar
    Jan 2006
    yer thank god i got mine up.. ii got the door panel off mine now.. but i need to remove all the plastic shit on the inside ov the door.. i think mayb just the front switch is shorted out or sumthing cause i realised that if the switch goes it breaks the circut to the back switch.. and i had a smell and it smells a little burnt out.. hopefully sumone will read this thread and help out!
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    it is the switches most likley...
    what happens is the switches tarnish over time causing resistance when it throws power. mine was the same went down and wouldnt go up and the motor would click i found if i reversed the polarity of the motor it would go back up.
    i fixed this by pulling the switch apart
    you have to pop the button part off (take care not to loose the tabs that go between the button and the contacts) and you will see the leds are soldered in and they have to come out to get to the switch apart to clean contacts
    so you take the leds out comletely (not to hard if youve used a soldering iron before) then seperate the two halves of the casing...
    now you will see that the dead one will be either badly tarnished or corroded
    so grab a little bit of sand paper and sand the contacts so they are clean then go test the switch while its in peices so if it needs more sanding you dont have to pull it apart again.
    that fixed mine and its been great since
    seth187 Guest
    Quote Originally Posted by HDT_aero
    Wouldent that just be a contact problem like...the window sometimes goes up and down, sometimes it works and dosent...
    If you can hear the motor working dosent nessesarliy mean its not that, it could be working but maybe some splines init that make the window go up and down are chewed out?.
    Take the door trim off, put the window down and go back up, if it struggles to go back put some force on the bottom of the wondow pushing it up and see if that works, if it does more then likly the motor in the regulator is stuffed or splines are damaged. Also make sure your window guides are clean of crud, if too much crap is in there it will make the motor work harder and eventually burn it out.
    Keesh's Avatar
    Jan 2006
    Quote Originally Posted by seth187
    yer i took the door panel off and am in the process ov taking the plastic protection shit off. ill hav a good look at it im just worried that one ov the wires sumwhwere in the car is damaged and will b hard to find
    seth187 Guest
    dount it will be the wires if you can hear the motor working when you press the switch. Keep me updated on what your doing and if ya fix it
    Keesh's Avatar
    Jan 2006
    i can hear the motor click wen the button is pressd.. it dosnt make a 'moving' sound
    seth187 Guest
    Ok, i dont have electric windows in mine so im not sure of the button set up in urs, but have you tried changing over the switches say from the passanger side and see if that works? If it does the same thing change the motor for the window and tell me how you go.
  1. Drivers side window problem
    By onthepony in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2008, 07:03 PM
  2. Drivers side window part.
    By epoxpro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 08:19 PM
  3. drivers side window stuck
    By azza009 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2007, 05:34 PM
  4. VT - Drivers side Window Issue...
    By bradwilks80 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2005, 11:39 PM
  5. Electric window prob (plastic tabs which slide into metal grooves)
    By HaRm in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2004, 08:14 AM
