for all thoes who want to know how to do a manual convert to their auto VN - VR heres how.
firstly you will need the gearbox, tail shaft, crossmember, clutch, clutch cable (recomend new), flywheel, spigott bush, pedal assembly, plastics and the wiring from the box to just infront of the gear shifter.
1: Pull out the Auto box, Torque converter and auto shifter. will require dropping the steering rack to get converter off. Also will require removing the exhaust
2: fit spiggot bush DONT FORGET TO OIL !
3: fit fly wheel to engine including the clutch (if using box out of a S1 VN and putting it in a S2 or later you will need the 8 bolt flywheel to fit.) 40Nm and lots of thread locker!!
4: Fit wiring through body plugs in just under the audio unit in frount of the shifter(ALL WIRING FOR THIS CONVERT INCLUDING THE COMPUTER IS THE SAME EXCEPT FOR THE LITTLE BIT THAT ATTACHES TO THE BOX ITS SELF. YOU DO NOT NEED TO CHANGE THE COMPUTER!!!!)
5: fit the plate to the trans tunnel and rubber boots round the shifter.
6: Fit box to engine and connect wiring dont forget to lube through out bearing (clutch release bearing) slide!!!
7: Fit tailshaft
8: Fit pedal assembly including the clutch cable there is a grommet in the firewall this will require droping the steering collum
9: fit plastics to centre console
10: ensure every thing is tight and oils is in gearbox!!!
11: test drive to ensure everthing is ok![]()
12: have a drink to congratulate yourselfand be aware of da
We highly recomend buying an entire damaged car ( rolled, pranged etc) from the auctions or wreckers to do this convert!!
we bought the one we used(VN S1 S pack ) for $1100 in good driveable condition.
please sticky this to top to make it easy to fing as it seems like everyone is looking for it everytime im on here
any questions feel free to pm me
