Results 1 to 6 of 6
Thread: spark plug prob
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default spark plug prob
    Today i decided to change my sparkplugs for the first time since i got my car. it was all good till i got to the last plug. the numbnuts that owned the car before me threaded it and cant get it out. well i prob could but its realy realy tight and im scared that if i get it out i wont be able to get another one in. does anyone have a solution to this prob that wont cost a fortune? cheers
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    it's a steel head champ, the likelyhood of you striping the thread out is not very high. removing the plug is easy, you spray the spark plug with some inox, and let it sit for a few minutes, and undo it. if it does snap, go and get yourself some easy outs, drill a hole in the center of the thing but not to far down, then you insert a easy out into the spark plug and it will come out.
    as for the re-taping the thread, well that is the fun part, mainly cuase when you re-tap the thread some of the old thread will fall into the bore, and it's nasty when that happens, if you are unsure, i would take it to a mechanic, either way, it will cost some money.
    cheers
    garth
    vn
    Jun 2005
    Apr 2006
    canberra
    yeah i gapped them all to the right size its just this one that is stuck thats a real problem. i dont have enough money at the moment to i cant take it to the machanic. you got any idea what it will cost to get it fixed?
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Most mechanics shops will have a thread chaser made for this problem.As they dont actually cut the thread the amount of filings that can get into the bore is minimised. It should take around half an hour to do.
    low-304 Guest
    just get a pro to look at it but u should be able to do it your self
  1. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  2. Spark Plug Gap???
    By markc3012 in forum V8 Development and Modification
    Last Post: 26-10-2005, 06:15 PM
  3. Spark Plug Help
    By sk00bs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-10-2005, 03:56 AM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. Spark plug gap???
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2004, 04:14 PM
