Results 1 to 22 of 22
Thread: Squeaking brakes, any ideas???
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Squeaking brakes, any ideas???
    hey, this only happens occasionally,
    the brakes squeak when light to medium pressure on the break is applied, any higher and it stops, it also squeaks when slightly turning left.. (front brakes)
    ive had the rotors and the pads done about a year ago,
    i took the wheel off the other day (for something else) and noticed a groove in my rotor, (single groove) is that ment to be there or could i have a stone caught in my brake pad???
    or do the rotors just need to be machined???
    any ideas, the cars a little overdue for a service, but ive had soo much work done to it (ie regular checkups) i havnt needed a service, (ie oil flushed, tranny service, changed coolant ect)
    soo yeah.. any idea??? (the power steering has a new pump/highpressure hose so the turning noise wont be that)
    cheers
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    yeah, just sounds like the rotors need machining man...thats what causes the squeaking 90% of the time
    seth187 Guest
    Probably the discs, the lip occurs due to wear from pads, makre sure the pads are ok too, squeeling can also occure due to crap pads, so go get your discs machined, make sure they will not be undersized when doing this.
    That should fix the problem
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    cheers, how much does it cost to get rotors machined
    my old rotors were undersized but these ones shouldnt be undersized, they're pretty new
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    5spd VN SS
    Jun 2005
    Yeah, picking up some slotted or drilled rotors would be the go. I think you can pick up new rotors off ebay for about $50 each, so that would be better than maching them.
    kilowatts are like drugs, the more you get, the more you want.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeha. but they shouldnt be gone after 1 year (keep in mind i only got my p's in november so the cars only had heavy use for around 6 months...)
    missus (in more ways than one)
    Sep 2005
    low-304 Guest
    whats the go did u fix them or what id replace the springs lol i had shit brakes replced my spings in the back of them and whola fixed the problem well i had a pro do it as im only 15 but do all the work on my car my self
    VN Wagon
    Jul 2005
    You can get squeel stop spray from supa crap auto.
    Just spray it on the back of the pads and they stop squeeking
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    wow cheers mazza
    ill try that, how much is it?
    CSL, those arnt slotted :P i hate replacing anything in my car with stock, its like an extra $40 with a free set of brake pads
    im getting my new ultra low kings (rears) from that shop next wedensday
    silver_bullet's Avatar
    silver_bullet is offline Now Genesis Blue Bullet
    vr commodore S
    Jul 2005
    moura
    hey bud, i live in the country and travil on dirt roads heaps, this brake stuff always happens, if theres a groove it is most likle 99% a stone caught on the pad, i fix mine by goin pretty fast in reverse then jammin the brakes on, normally pulls them lil stones rite outa there, u wouldnt have to waste money on gettin ur rotors done, but if this dont work looks like ur to late and the stone has worn to much and is stuck in the pad, but to anyone out there try my trick first before spending money, most of the time it should work if u do it not long after u first hear the sqeak. hope i got to ya before ya spent money.
    seth187 Guest
    Quote Originally Posted by silver_bullet
    99%? dont think so, the groove is caused by wear from the pad, either the brake pad is down to metal and screwin up the disc, or its just wear, all my time doing discs and brakes i have never found a stone embedded into a brake pad and rubbing on the disc. If that were to happen it would make vertually a constant squeel.
    Btw, dont change your springs, the squeeling is not from that.
  15. #15
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by seth187
    LOL who said that i wanted to change the springs to remove the squeak??? i want new springs to lower the rear end more
    i found some stuff at super crap auto for $12 that u put on the pads
  16. #16
    seth187 Guest
    Quote Originally Posted by PaRaDoX616
    Have you actually checked out the pads to make sure they are not work out?
    The spray will only last for a bit, then the squeel will return.
  17. #17
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah ive checked the pads, my geuss is they're cheap pads, only fronts do it,
    was considering getting 2x slotted rotors with a free set of pads ($165)
    and by the way did anyone actually read my first post?? only had the pads/rotors done a year ago, and only been driving the car lots for 6 months (got my p's)
    il try the reverse trick but its probbly just due to crappy pads, the spray will stop it for now untill i can be ****ed buying new rotors :P
  18. #18
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Mate, I had my rotors machined and brand new front pads on mine in August last year. They were squealing right after I drove out..
    The pads were "Premium" according to the mechanic. (not a mechanic I've used since, or ever will)
    I've asked a few people and some just squeal. It's most likely just the brand of pad, if you're braking is fine, just suck it up..
    Try the spray though. I haven't.. I honestly CBF.. My braking is fine, I'm happy..
    Shounak
    Always Right
    My Ride
  19. #19
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah, brakings better than fine, the car will skid before the brakes wont hold
    oh well ill upgrade to slotted rotors some time
  20. #20
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    My Brakes r geting bad, Its ok if i dont do any moderate to hard braking, but once i press down too hard she will squeel like a MOFO. It also hapens when i turn left or right but when the wheel is straight it wont squeel. Im pretty sure my brakes r ready to be replaced with new pads and rotors. When i have the money ill have to get some slotted rotors and new pads. The rear rotors can be done too cant they?
  21. #21
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    no point in doing rear brakes really, they're only used by the hand brake, and unless you've been using the handbrake to drift then i dont think they'd need doing, just get some slotted/ventalated rotors off onlineperformance auto's ($160 with a free set of pads), that squealing like a mofo is called singing lol, it probbly means your down to the metal at the end of the pad and your putting groves in your rotor (not good lol)
  22. #22
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Thanx Para for the heads up lol. Garh, too ebay i go...
    EDIT: Went to ebay and check for slotted front rotors and brake pad deals and coudn't find any! Can anyone else fond any?
  1. squeaking noise in air con.
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2011, 11:06 AM
  2. squeaking noise from the engine
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2006, 12:43 PM
  3. Squeaking Brakes?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 06:14 PM
  4. Diff squeaking
    By VSBerlina95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 02:31 PM
  5. Creaking/squeaking GTR
    By rubygirl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2005, 12:48 AM
