Results 1 to 10 of 10
Thread: too much oil
    vpads Guest
    Default too much oil
    does anyone know a way to syphon oil out of the sump? maybe thru the dipstick tube?
    I accidentally put five litres of shell helix semi synth in and it is way over on the dipstick and i have noticed fuel consumption is up and the car is running a little rough now
    Aug 2004
    S.E. Melb
    loosen the sump plug off enough to allow it to drain slowly and drain about 1.5 litres out.... syphoning? I've syphoned petrol out before and that left a nasty taste for about 3 hours..
    -dave
    vpads Guest
    thanks will try that one... makes a bit more sense. have syphoned diesel down my throat cant imagine oil would be any better!
    VE Berlina International II
    Nov 2003
    i wouldnt drive your car with that much oil in it, youll need to get it out quickly, if your going to be driving it
    Thats all right, thats ok, I drive a commodore anyway!!!!
    Vz Sv6
    Jul 2005
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    if you over fill your car with oil you can cause an hydraulic lock in your engine
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    VS Commodore Acclaim
    Jan 2006
    To get a hydraulic lock the oil would have to be several times more than the sump holds. The main risk is to the following:
    1] The oil could be whipped to froth if it comes into contact with the crankshaft.
    2] The expansion of the oil could pop a seal or run out of any non contact seals such as front crankshaft seal if its the type that runs in close proximity to the crankshaft or is a felt seal (I'm talking general here because I think the commodore engine has a lipped seal).
    3] Oil could be blown out the dipstick tube and I have seen an engine where it lifted the dipstick up enough to vibrate out when the engine was reved (4cyl engine had 8 litres in sump when mechanic put oil in the sump and his ever helpful apprentice came back from the loo and put some in as well).
    seth187 Guest
    VX exc & VP exc
    May 2005
    vpads Guest
    ok looks like i will have to drain it from the bottom and get dirty hands
