Results 1 to 7 of 7
Thread: vn a/c & fan not blowing air :(
    STYALR Guest
    Default vn a/c & fan not blowing air :(
    hey guys i have a problem, my a/c and fan isn't working just recently i had my headunit installed and ever since that it hasnt seemed 2 work.
    the knob which u turn 2 either front dimister etc isnt blowing air and my windows r getting all foggy and the slide which has the numbers 1 - 4 wiv the little fan symbol doesnt do anything wen i slide it across wat cud b the problem?
    as i stated cud it have sumthing 2 do wiv getting my headunit installed? thanks in advance
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    search for 'fan resistor', that should help ya, or if not check all your fuses and relays and stuff
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    VP WAGON V6
    Mar 2006
    check to make sure the plugs are all plugged in at the back.. that would be the first place to start. If you got it proffesional installed take it back to them and say that it was fine before took it in. If you did it yourself chcek those plugs etc...
    STYALR Guest
    kirkson is offline Captain
    93 vr v6 exec duel fuel
    Oct 2005
    Definately fan resister, located under left hand side wiper blade,regards kirk
    Captain
    Calais V
    Jan 2006
    it may be the fan resistor, located under the black plastic wall , under the left had side wiper blade.
    if when you slide the fan speed slider switch, and on some numbers the fan does work, and on one or more it does not, its definitley the fan resistor switch. few bucks from a wreker.
    but if none of your fan speeds work, may be other, so also try other fuses as well.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    make sure you put the vaccuum tubes back on the right way...took me many months to track that hissing down!!!
    aZK.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. Air box blowing up
    By goodyear in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2007, 09:42 PM
  2. wk blowing fuses
    By caprice123 in forum Electrical Wiring / Questions
    Last Post: 23-12-2006, 09:09 PM
  3. 202 blowing stuff
    By 85berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-07-2006, 10:48 PM
  4. Fuses Blowing
    By jamiekratin in forum Car Audio
    Last Post: 24-03-2006, 05:37 PM
  5. VR Blowing Smoke
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 10:19 AM
