Results 1 to 11 of 11
Thread: Car Nearly Didnt Start???
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    Default Car Nearly Didnt Start???
    Had about 1/4 tank of fuel left and just filled up.When i started the car it turned but didnt start it just missed from fully turning.So i went to start again this time holding key for long time and it wasnt going to start but i gave it some throttle and it started.
    ANY IDEAS ANYBODY
    oh i ran a fuel cleaner on the previous tank but i run one every 3 tanks anyway, but this one was different.(this one smelt like windex-alcohol based not petrol based like the usual one i use and it is meant to last 10,000k's)
    I HOPE NOTHING EXPENSIVE IS ON ITS WAY OUT
    And also my exhaust sounds very poppy like the airflow has no pressure through it.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    well.... if you needed to add some air into the chamber then it seems like its something to do with your throttle body, reset the idle air control valve, check the TPS refrance signal, maybe even clean your throttle body with a cleaner
    could also be a that fuel cleaner has damaged your cat converter and has excess carbon buildup which restricts airflow when cold
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    just cleaned the TB last weekend (had to make own gasket from special gasket paper as i was told the original ones are hard to find.How do i check the IACV and TPS.Also my high flo cat is only about 1.5 monthes old.
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    mine does this once or twice, not very often at all. but some times it doesnt start right so i turn it over again and it just keeps turning over till i give her some gas, my tb is clean as a whisle but as i said its once in a blue moon
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    VP WAGON V6
    Mar 2006
    i think its a commo think.. my wags doess it everynow and again.. its worse when you get nothing when you turn the key.. lol
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    mine always does this, actually just tried to start her then and did the hole turn over thing then started making a coughing sound like it was pushing air out of the intake... gave it a bit of gas and fired straight away. does someone know wtf is wrong wiith my car cos it is starting to give me the shwits and it has me stumped on what is wrong with it.
    cheers...
    YMY-88U's Avatar
    Project VH SL/E
    Jun 2005
    come on people there must be someone out there that knows whats wrong with it or had the same problem cos it starting to get embarrassing whenver i start the thing.
    missus (in more ways than one)
    Sep 2005
    i find that if i turn my key but dont let the starter turn enouhg, i.e i should hold the ey for longer, it will almost start then conk, then somtimes after this it wont start for about 5-10 seconds of turning the starter motor, almost like it needs to find more fuel. My advice is to hold the key down untill it's good and started, get some good quality injector cleaner or get them professionally cleaned, get some new spark plugs and make sure their gapped right, if your leads are olf et new ones.
    and if this doen't fix it get back to me
    Jarrodk Guest
    Same thing is happening to me and it sucks.
    But it wont even start when i put foot down =[
    Jarrodk Guest
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    When mines warm the starter motor will just keep cranking it over untill I give it some gas. Starts first time when cold though...
  1. Just doesn't start
    By Wojzilla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2006, 06:38 PM
  2. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  3. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
  4. Can I fit airconditioning to my 92 VP aftermarket (didnt come standard)
    By rharman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2005, 08:43 AM
