Results 1 to 10 of 10
Thread: vn has oil but hasnt
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Default vn has oil but hasnt
    hey guys
    just a quick question, i have a vn 3.8 and when you drive it hard the oil lite comes on,the car becomes very slugish and the lifters start making noise, when you stop and check the oil level , the oil is on max, can anyone please help me with this situation, any comments would be much appreciated
    chris
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    your oil pickup in the sump could be dirty and particially blocked and therefore when you hammer it it is needing more oil but cant pick up anymore.
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    vpads Guest
    might be too thin an oil so when u thrash it it froths a bit meaning it doesnt get sucked thru the pickup
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Oil pump could be on the way out, it might be okay at idle, or crusing, but underload it could be having problems.
    I'd go with a dirty pickup first though.
    Gravity is proof that nature keeps getting us down.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check your bolts that hold the oil pump on. They can come loose so the oil pump will suck in air instead of oil.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    All good suggestions, but my bet is on the pickup, as a lot of early VN's apparently had a problem with it clogging up. So yeah, basically, when the oil light comes on, it means that pressure has dropped below safe levels. If the amount of oil in the engine is correct, then the fault has to lie within the cirulation system somewhere, unlikely to be a major blockage in a gallery as that would be unlikely to occur and would probably also cause problems at all engine conditions (not ruled out but unlikely). So in terms of major components, you're left with the pump and the pickup. Either way you're going to have to at least drop the sump, a major pain in the arse. The procedure can be found on here with a bit of a search, or better yet grab yourself a gregory's manual OR pike out and get a mechanic to take a look. If the pickup is blocked it will be fairly obvious, I seem to recall seeing a picture of a blocked pickup on here somewhere. Anyway, fairly common problem, can be fixed. :-)
    missus (in more ways than one)
    Sep 2005
    try changin the oil pressure sender, 17 bucks from bursons, that could be you rproblem
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    vn88calais's Avatar
    vn88calais is offline Perth Representative
    VY Commodore 2002
    Jun 2005
    Perth, Western Australia
    might just be blocked oil cooler hoses or oil hoses, have a look, but u might drain oil, get them to check or check ur self if u do ur own services...amybe the filter also?
    also u said early vns had problems with clogging up, well i must be really lucky, no dramas like that for me!! *touch wood*
    cheers, Todd
    VY works currently in PRODUCTION!!
    Engine will still be sloow!!!!! ;-)
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    has it had regular oil/filter changes?
    if it's sludged up you will need to clear it up or risk breaking the engine.
