Results 1 to 5 of 5
Thread: 2 piece tailshaft V 1 piece
    vn 5ltr + bt1 pack
    Dec 2005
    YOUNG N.S.W.
    Default 2 piece tailshaft V 1 piece
    I am concidering changing my 2 piece tailshaft for a one piece? has any one done this? My car is only lowered to fe2 height. Will it make the drive ruff, Your opion would be greatly appriciated.
    I didn't do it
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Why do ya wanna do that? In my opinion it would be a very expensive exercise in futility, but as long as it was well balanced it probably wouldn't feel any different at legal speeds. Ford are still running a one piece tailshaft, or they were up to the AU, which is why base models were limited to 180km/h. Theres gotta be more important things to spend the money on though right?
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    Quote Originally Posted by pandaman
    Some of the B series Ford still run one piece tail shafts.
    The good thing about a one piece is you have less loss thru the drive line of your car. But I dont think you would be able to do it on the VN model, with clearance problems.
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    Ideally our cars are running live axle and having one piece shaft would cause some issues due large movement of the diff moving around. If the car has IRS then it could be ideal but there would be some drive line vibration. The reason for having 2 peice shaft is to minimise driveline vibration also reduce the angle of movment from the gearbox to the center bearing which would keep the seal aligned reducing wear on one side of the gearbox case.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by vztrt
    Less drivetrain losses is a valid point, but the power lost through that one joint/collar would be absolutely bugger all in the grand scheme of things.
    Well put SlowVac, although live rear axle falcons don't seem to have too many problems related to tailshaft angle, I do have a vague memory of a bloke who did something particularly odd to the suspension on an X-series who kept chewing unis, but thats the only incident I'm aware of.
  1. Cig Lighter piece
    By parkerst in forum Parts And Other Items For Sale
    Last Post: 14-03-2007, 08:18 PM
  2. Cig Lighter Piece
    By parkerst in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2007, 05:25 PM
  3. Abs Piece Below Sterio
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2007, 09:28 PM
  4. One piece tailshaft
    By bigal in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2006, 12:50 PM
  5. piece of this?!
    By -davo- in forum Jokes/Humour
    Last Post: 11-06-2006, 08:00 PM
