Results 1 to 15 of 15
Thread: Engine warning light keeps coming on how come ?
    Ygoford's Avatar
    Ygoford is offline YGOFORD?
    Vr
    Mar 2006
    Question Engine warning light keeps coming on how come ?
    When i turn my car on ( not everytime) the engine warning light comes on for about 30secs to a minute then turns off , my friend thinks its just cause the engine has to heat up or a missfunction , it doesnt effect the car it still runs like a dream and i've never had a problem with it , the oil is always full and same with coolant and i get it serviced regulary , anyone know what it is ?
    With Great Horsepower Comes Great Irresponsibility
    Jun 2005
    run a diagnostic and tell us what code it comes up with
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    My00 Wrx 240kwatw
    Apr 2005
    4DSSUX Guest
    KarlgotVNcommo Guest
    Airflow meter is in the throttle body. Run a diagnostic test and it will tell you where the problem is. I just fixed mine today. Vacuum hose I forgot to put back on when I put in my big-bore Yella Terra throttle body today.
    Diagnostic works good. Needed the Haynes manual to tell me how to do it.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Actually...the VN's didn't have an airflow sensor. They have a manifold air pressure sensor.
    Use the search function, there's plenty of threads here that list how to check codes.
    Gravity is proof that nature keeps getting us down.
    Ygoford's Avatar
    Vr
    Mar 2006
    1 i dun know how to do a diginostics test lol or how to spell it , 2 theres nothing wrong with the car it just does it for like 30 seconds then turns off and doesnt do it again till i turn the car off leave it and turn it back on
    ..... went in a vyss the other day **** mmm yummy !
    VT Calais Super6
    Jun 2005
    im laying odds that you have extractors, in which case its your oxygen sensor reading. Normal though, mine comes on all the time and its a new 02 sensor put in with the pacemakers.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    mine comes on all the time 2 for a min or 2 then goes off at any time while driving (random not just at start up) i did the test and got no error every time 12 i think
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    mines comeson while driveing i get a code 44 lean fuel or sumthing all you need is a paper clip and you have to find you diagnostic lead its under the passenger side kick panel neer the door then i think im not 100% sure u join the black and white wire to the white i think hopfully someone else will explain better then u turn your car on to accesories and the engine fan should come on and the engine light should flash a code up oh i found the link here you go check this out Checking your Computer for Faults (VN - VP) tell us how you go
    Ygoford's Avatar
    Vr
    Mar 2006
    Wink
    Quote Originally Posted by nathans1987
    i think this is whats relating to mine , i dun have extractors and have check the air flow and dun seem to have a problem , thanks for ur opinions guys
    opel calais 2.6cc dual ram
    Apr 2008
    KUALA LUMPUR, MALAYSIA
    hai , im nizam from malaysia my opel calais VR caprice appear this.... When i turn my car on (everytime) the engine warning light comes on for about 30secs to a minute then turns off , then appear again on & off .. but, it doesnt effect the car it still runs like a dream and i've never had a problem with it , the oil is always full and same with coolant and i get it serviced regulary , anyone know what it is ? thank u all
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    firstly welcome to the forum and congrats on a first post epic dig.
    do this
    it'll tell you what the fault is.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by neonizam View Post
    If you can I'd check for error codes stored in the ECU
    The small plug under the glovebox will need to have a wire put into the 2 terminals on 1 end and turn on the ignition. The electric radiator fan will run to tell you its in diagnotic mode and the engine light will flash at you.
    code 12 = systems are all good. So it will flash the code 3 times.
    There is bound to be many many threads on this forum that will explain the code process in much more detail than me.
    This will tell you what area the system fualt will be.
    and 3 Dangerous non ABS VN's
  15. #15
    Apr 2008
    thanks guys 4 ur help....
  1. Engine check light not coming on!!
    By bladerunnerkim in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2007, 11:03 PM
  2. engine warning light..
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2007, 10:51 AM
  3. Engine Light keeps coming on
    By Naughty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2006, 03:08 PM
  4. About Engine warning light
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2006, 07:34 PM
  5. oil pressure warning light not coming on on startup
    By commodorewannabe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 10:56 PM
