http://cgi.ebay.com.au/VN-Commodore-...QQcmdZViewItem
i have found this on ebay. is this what is required to fit and lsd or is there more two it. is it simpy a case of taking out and changing the gears. or do u need more any suggestions
That's just the two gears you need for a ratio change, there is another bit in the middle with little gears, that's the bit that's different in a LSD
if you have a vn it will already have 3.08 gears. that person is only selling the gear not the centre. you need an lsd centre. don't worry about what gears a centre has if you are after an lsd cos you can put what ever gears you want on the centre.
you got in just before me.. hahaha
so how much would the certre set me back and is it easily installed
