i was just wondering what is the go with the above injectors. people list them on ebay as highflow injectors. is ther eany benifits of them. they are rated about the same cc's as 901 standard injectors..
they are 24lb, the std 901's are 19lb
the "benefits" are that you need to get the memcal reprogrammed as it will run badly, no performance advantage at all, the engine will only run correctly with the correct amount of fuel, put more fuel in & it will run rich & make less power, & get horrible economy
Rob
I did a thread on Injector Upgrades Injectors Upgrade For 5 Litre 304 V8Originally Posted by defa
there is some handy info there for ya
Cheers.![]()
* RVN 355 *
acording the a web site i looked up the 775 injectors are 19lb aswell.. here is the site http://users.erols.com/srweiss/tableifc.htm
so far any other injectors i have looked up hae been right.. maybe the 775 ones are wrong on that site
these bosch 775 blue top injectors are standard on any 2.6 tr/ts magna..you can pick them up at wreckers cheap for set of 8 ..must of sold 20 sets over the years...
defa i have a bag of creamtops sitting round somewhere, needs some new o rings but should do the trick...
