Results 1 to 24 of 24
Thread: has any got a rear strut brace on there commodore
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Default has any got a rear strut brace on there commodore
    i was just wondering if anyone had a rear strut brace.
    05 VZ
    Nov 2005
    na mate but if they are half as good as the front strut braces id buy one
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    vnberlwagon Guest
    Quote Originally Posted by vpv6wagon
    Made one at work, and it works bloody awesome!!!
    Doesn't a Panhard Rod do the same thing?
    VN Commodore
    Feb 2006
    i thought the panhard rod stops the diff from moving from side to side.. cos if you get an adjustable one you can adjust the diff over to one side so the wheels don't scrub when you lower your car.
    that is what i have been led to believe but i could be wrong there
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    i want one of those bars that run across the floor in front of the back seat... mounts to each side of the body and goes over the centre bit.... donno what its called but i want one...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by defa
    yep - in a roundabout way that sounds like EXACTLY what the panhard rod's there for.
    not wrong at all
    stops extremely low cars from crabbing, too
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by azkwazere
    aZk.
    yeh so do i the only ones i have seen r from monkey warehouse but im going to try to make one of them aswell when i get some time at work.
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by 1991_Vn2nV
    Who sells rear strut braces for VN's?
    i don't know if anyone sells them for commadores but i think whiteline sell them for rice. i saw a pic on there website but they didn't have one for vn/vps. thats where i got the idea but mines a bit different faily simple 2 make though. i'll try and get some pics on 2morrow.
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    1991_Vn2nV's Avatar
    Mar 2006
    Do you think its more effective on your wagon than what it would be on a sedan?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    i don't really know wheather it would more effective on a sedan or wagon, but it made a huge differance to the wagon in keeping it flat around corners. after putting a whiteline strut brace on the front i could still feel the rear rolling when cornering but now it just stays flat. how different is the strut setup on a sedan compared to a wagon?
    1991_Vn2nV's Avatar
    Mar 2006
    Im not sure...im not familiar with the setup on the wagons? If only i had the ability to make a rear strut brace myself. Sounds well worth while...
  15. #15
    foammedia Guest
    Try as I may for the last few hours, I can't see how this does anything at all
  16. #16
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    In a wagon you've got a bit more open space, in a sedan the metal of the parcel shelf is 'supposed' to stiffen it up and keep it all tight.
    but I'm with foam on this one, I can understand why the front moves around a bit, but can't see why there would be much play in the rear. That said, if you say it works for you then it's a good thing.
    Gravity is proof that nature keeps getting us down.
  17. #17
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
  18. #18
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by foammedia
    i dont really know how it works but it seems 2 stiffin the rear up heap i think it has something to with weight transfer, i went from flooring it around a tight roundabout and having the inside tire just spinning its guts out(openwheel diff) to it just lighting both tires and sliding and no big whiplash when straightening the car up
  19. #19
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    No ones going to sell a rear strutbrace for a VN commodore because VN Commodores don't have rear struts. They have a five link live rear Axal.
  20. #20
    foammedia Guest
    That's right, so there's no pressure on the shocker mount at all, or anywhere except the panhard rod so the bar can only do exactly nothing but the power of thought is everything
  21. #21
    Jan 2006
    stanthorpe, qld
    but i like imagining lol.
    but there is no real way to prove if it works or not
    Adam
  22. #22
    VY SS
    May 2005
    SA
  23. #23
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    oh well it made a difference 2 my wagon and i don't think i am imagining because i didn't really think it would do much in the first place and i know how my car acts.
  24. #24
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    American Autos sells all of that kind of stuff. Check out Street Commodores mag for rear panhard rods etc
  1. How do i fit the strut brace??
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 02:06 PM
  2. HDT Strut brace
    By jasonhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2006, 05:20 PM
  3. wtb vn strut brace
    By bennyballbag in forum Swap / Wanted to Buy / Trade
    Last Post: 14-11-2005, 11:17 AM
  4. Rear Strut Brace
    By Snap in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-10-2005, 06:43 PM
  5. Strut Brace
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 12:54 AM
