Results 1 to 10 of 10
Thread: Bellmouth Gaskets
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    Default Bellmouth Gaskets
    ive taken the bellmouth out and was just wondering should i put both gaskets back in or just the one.
    cheers,
    Jamie
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    just one will do
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    fu2's Avatar
    fu2
    Jul 2004
    VY S2 Berlina
    Jul 2005
    no worries, i normally buy a new one when i do that, but just use the best one of two and make sure bolts done up tight
    Current: My Ride
    Previous: Ride 2
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeah, just use the best looking one out of the two. It was a fun little excersise that belly removal. Good time to clean your TB by hand.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    The VN Series 1 V6 had no bellmouth and only 1 gasket in there.
    If you break a gasket, just trace it onto a bit of cardboard (cereal boxes come in handy here), cut it out and smear light grease on both sides to make an airtight seal. This will do as a temporary fix for any gasket in your air intake.
    I actually put a bellmouth in to my engine, just so it'd run smoother. Worked, no noticeable power loss.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    an idea if you want to keep the car smooth, but get better airflow, is hack up the bellmouth. dad did it for his vr, breathes better and is still smooth.
    cut off the top 90% of the bit that goes into mainfold, leaving the bottom curve there, to retain even airflow, then file out the remaining plastic, so its flush with the sides of the intake, use the elbow for reference.
    i shouldve gotten pics at the time. could probably whip something up in a 3d app sometime.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I can say that when i removed myne there was a noticable power increase, this is different for all cars tho.
    VY S2 Berlina
    Jul 2005
    yea same with mine, but it idles rougher on mine
    Current: My Ride
    Previous: Ride 2
    fu2's Avatar
    fu2
    Jul 2004
    mine doesnt idle any different. i think it might be the cai that helps that. also i have found it accelerates quicker.
  1. Removing bellmouth
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2009, 09:15 AM
  2. Bellmouth
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2006, 11:35 AM
  3. bellmouth
    By executive_power in forum General
    Last Post: 31-07-2006, 09:32 PM
  4. Bellmouth Removal Help
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 10:04 PM
  5. Bellmouth
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 07:47 PM
