ok i have taken my throttle body and that off to replace the elbow gasket (where the bellmouth was) and put it back to gether.
thats all good intill i start the car and it is reving atleast 500rpm more than it should.
why is this and does anyone have a fix for it.
cheers,
jamie
check the alignment of your TPS, if it is out it will rev higher than normal.
Undo the two screws holding it and move it side to side until the revs drop to normal.
VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
where about is the tps sensor. have your got a pic.
thanks just got to fix it tonight.
cheers,
jamie
yeah ive dont the rev it to 2000 odd revs. also took it for a drive and turned it off and started it again. still hasnt worked
try adjusting the throttle cable, losen it off a bit cause it could be tight and holding it open a little
THERE IS NO REPLACEMENT FOR DISPLACEMENT
throttle cable looks fine. i played around with it and didnt help it any. it is alot worse in park and neutural. probally 200revs more in gear. has anyone got mre info on this tps sensor
there should be a little screw that moves the throttle plate open at the back of your throttle body...unscrew this right out and see if it helps
BTW the tps switch is the on the bottom of your throttle body
TPS is the black thing on the bottom of the throttle body that is attached to the shaft that the valve sits on.
It is possible that you've split a vac hose, or a gasket and that there is an air leak that's stuffing your idle up.
Gravity is proof that nature keeps getting us down.
vacuum leaks drops the idle rpm and makes it run like dogs breakfast... but have you noticed a loud hissing sound???
no loud hissing that i can hear. the gasekets are fine (i made sure this time)
well if its no loud hissing then its probably not your idle air control.....sooo can you check the throttle plate screw on the back of the T/B??
i will have a look
just finished looking. it didnt work so i pulled the whole lot apart and put it back together and now its fine. cant work it out but not going to complain now. :P
cheers everyone for there help
jamie
