After fixing the rear aftermarket central locking actuators i shut the door and then found the door jammed form both inside and outside. The central locking still works but the button doesnt come up all the way. I could probably fix it but im not sure how i could do it if i couldnt open the door and also i cant get to the red area on the lock to take it off
you might be able to lever the door card enough so it doesnt bend, and get your hand in there, its a tight squeeze but it can be done. i had my door shut with child lock on and the door had a stuffed outside handle, so i did it that way. someone else might have a better idea but thats my 2 cents worth, lol
THERE IS NO REPLACEMENT FOR DISPLACEMENT
Fixed it, turns out there was a big bolt blocking of movement to the door lock, took the bolt out and now its perfect
