I'm looking at buying a VN. It's a series 1 and the engine in it, is apperntly seized, i would like to know, if the all VN and VP V6's use the same harness, ecu etc? I thought of going for even a VR engine, but they are all the same, basically. Anyone share advise.
the looms on series 1 and 2 are different. i think some of the plugs are even different.. i have a series two car and put a series 1 motor in it. i ended up using the series 2 loom. there was only two wires i had to change.. make one longer and i think the other one had to go shorter.. no trouble at all... i spose vr would be be different because of the electronics on the gear box.
