Results 1 to 11 of 11
Thread: VN Calais questions
    al9
    al9 is offline Banned
    May 2006
    Default VN Calais questions
    Ey peoples
    im looking to purchase a vn calais shortly just for winter use as riding in the rain on a litre bike isnt much fun.
    What are some main issues to look out for on VN's?
    Do the vn calais have keyless entry and central locking?
    Do the series 1 and 2 have the digital odometer? what are the other functions of the 3 lil screens below the cluster? eg trip computer functions?
    The series 2 have have the 147kw engine right?
    How long do these engines and transmissions normally last on these cars?
    can someone put a link up to a site that has specs and pics of vn calais.
    thanks peeps
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    ok...usual issues, leaking boot, rust (espacially around the rear window), power steering probs, and general non-functionality of some electrics (eg. rear elec windows).
    vn calais come standard with central locking and an alarm.
    all vn calais have the digital trip computer...which will tell you dist. till empty...km's travelled...odometer.etc.
    series ll doesnt have a 147kw engine..thats the ecotec engine (vs-onwards).
    with good maintenance and being well driven (not thrashed), the ol' buick will last well up to 300k+..the 'box will really depend on how well the car was driven and serviced, usually 250k (around that) you'd expect to overhaul the 'box.
    redbook has specs for the vn calais.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    vn calais come with remote entry / central locking... getting one with a working remote is doubtful,
    electric windows are a pain in the ass lol.. replaced 3 motors so far...
    series 1 has 127kw
    seies 2 has 125kw
    despite what most sites says and anyway, thats at the fly wheel.. a stocky vn on the dyno would pull 85-95rwkw if they're lucky
    DFI moduels tend to brake, ive replaced the power steering pump/hoses
    crank angle sensor, check for rust aswell, also check for a straight body (all panels fit together nicely)
    overall the only real advantages it has over the vn exec is
    power everything
    nice seats
    a 2 tone paint job
    cruize control
    and a funky grille with calais badges
    also its around 70kg heavier
    they're what? $500 more than a exec lol, i was lucky and scored mine with a mint interior for $2500, 265k on the clock now (250 when i got it)
    engines going hard, had to replace the suspension
    also vn tail lights are a pain in the ass, mine was fine... right up untill i backed into a magna and created a leak in the boot (metal shifted where it was tact welded) and the wiring loom got rooted,
    over all its a reliable car if you treat it with respect, easy to find parts for which is a bonus!!!!!
    al9
    May 2006
    thanks for the info guys
    i bought a eb fairmont 6 years ago and that had a decent interior for its age so i dont want to go backwards comfort wise
    any other input would be great
    thanks again
    VN Calais 5.0L
    Feb 2006
    I have a 89 5 litre calais for sale if you are interested, i am in sydney....
    al9
    May 2006
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by PaRaDoX616
    series 1 has 127kw
    seies 2 has 125kw
    With the electric windows, I just gave the solenoids a bit of a whack and they worked....but i didnt use my rear windows for a weak and they stopped again...gave them another whack and ran them up and down like 50 times and they have worked since. I think alot of the time it is just the solenoid and unfortunately its a whole unit so u cant just replace the solenoid by itself.
    Also its Series 1 has 125kw
    Series 2 has 127kw. You got them confused.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    i know in the books it says 125kw for the S1 engine, whacking the solonoid really work??? when i brought my car the drivers side worked perfectly, the rears didnt function, and the, passengers side front was getting jammed due to a loose seal, replaced 1 motor and it works perfectly, ive tested the last non working window, the wiring / switch is good, might give it a go, did u rip the motor out to whack it or just take the trim off??? my car was a family car before i owned it, a common problem with the power window switches were fiddled with lots lol, and sometimes wared with parents, i dont think motors like being told to go up and down at the same time... lol
    back on the S1/S2 motor, i believe that statistic was wrong due to the restrictor to fix the S1 crap idle, anyway id like to see a vn pull 125-127rwkw on the dyno stock lol, thats the thing i dont like everything should be measured in Rear wheel kilowatts not at the fly wheel, as thats what matters!!!!
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    The trick is though, that it's not the power that's the really important part, the V6 produces massive amounts of torque, that's why it's so easy to loop them in the wet if you aren't used to driving them.
    Gravity is proof that nature keeps getting us down.
    1991_Vn2nV's Avatar
    Mar 2006
    There are many changes in the engines from the original S1 to that used in the 1990 models and then again in the 1991 models. From the crankshaft to the cam. And the VP is 127kw which is the same engine as the 1991 VN's. After 4000rpm, the series one engine drops off more rapidly in torque and also flattens out in power (although not severely).
    As for the power window, it was my right rear window that didnt work as well. I just took the trim off. I think the fact that i used it like 50 times afterwards re-enacted the connection on the solenoid. My left rear window actually wont work now, im planning on doing the same thing when i get the time.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah i took the trim off today to test what blue vinal looks like, (fake leather)
    anyway gave the solonoid a good whacking with no luck, its the motor thats blown or the solonoid is just rooted, anyway lol this is the 3rd door trims ive gone through, (stock calais... its ok but looks dirty, then bright blue, too bright for me, now vinal.. its a good material except the colours not as birght as i want, kinda looks dark blue/green. oh well...)
    yeah thanks for hte tip anyway
  1. VK Calais Questions
    By s_pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-04-2007, 06:06 PM
  2. VE Calais Questions
    By MikesVT in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-03-2007, 08:31 PM
  3. questions on mods on a new vl calais
    By danny_sway in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-04-2006, 06:00 PM
  4. VXII Calais Questions
    By WonNewUser in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 11:21 PM
  5. VT Series 2 Calais - A few questions...
    By metaxus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 08:23 PM
