i was just looking round on the net and came across some infothat said that the oil pressure sensor is on the same pin on the aldl as the fuel pump test
i have been having a problem with my vp stalling intermediatly while driving and when i try to start it again the check engine light dosent light doesn't come on but if i have it turned to on and put a paper clip between the 12 volt and fuel pump test (theres a few blue sparks coming off the paper clip) then the check engine light comes on it will start and run fine? does anyone have any ideas i was thinking it might be a faulty oil pressure sensor?
