Results 1 to 4 of 4
Thread: how do i remove rear right door trim?
    gocommygo Guest
    Default how do i remove rear right door trim?
    have probs with the lock and need to take off the door trim, how do i do it?
    missus (in more ways than one)
    Sep 2005
    you will find the lock, on it is a little orange strip when open, get a small flat head screw driver and pop the orange thing open, it will slide off
    as for the window winder get a small rag andn put it between the trim and the winder and mover it around, yo shoul pop off a small clip,. then the winer should come strait off, with the handle, pop of the cover and undo two phillips screws, then jus yank the trim off and there you go
    VNSS Atlas Grey
    Feb 2006
    1st of all, unlock the door and you will se the red thingy on the lock switch, you need to lever that thing out with a small screw driver. it should click out eventually and the switch should just slide off. behind that should be a screw, undo it. next take the covering panel off the door rest handle and undo to two screws behind it. After that it should be a simple task of just pulling the door off from the clips remebering to pull from the bottom first.
    VN V6 Commodore Executive....and a London bus
    Dec 2005
    My door trim came off by itself, it was soooo helpful :P
  1. How-To remove trim clips.
    By The Darkness in forum Holden Commodore How-To's
    Last Post: 02-04-2007, 08:38 PM
  2. Remove interior door trim??
    By Low_VX_Taxi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2007, 10:06 PM
  3. VY/VZ Passenger Side Rear Door Trim
    By Marzz in forum Swap / Wanted to Buy / Trade
    Last Post: 26-02-2007, 08:29 PM
  4. Rear door trim for wagon - sedan the same??
    By mad13b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2007, 08:58 PM
  5. Help for removing rear door trim & tips on parint touch ups please
    By lobedowg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 02:04 PM
