Yesterday I took out my speedo to replace that little odometer cog to get the odometer working again. Anyway, that was relatively easy to do and had no problems. But when I put the cluster back in, the speedo doesnt work properly...its like...whateva turns the dial is only just working. Because it'll go up a few km/h then stop...and the speedo is nowhere near what speed im meant to be doing. I know its nothing to do with the speedo sensor because its only just started not working when i replaced the odometer cog. Any ideas as to why it does this? Or should I get a new cluster, or get an auto elec to have a look at it?
Mate,
If you get stuck i have a complete dash cluster with Tacho etc that i have just removed out of a car that i have. Vp
If you are intersted let me know, make an offer.
If not good luck with your old one.
Catchya!
Pete 0438 452 923
how much do you want for it?
i have no idea how much a cluster is...
