Results 1 to 11 of 11
Thread: Dash Light (!)
    OFFiTS's Avatar
    OFFiTS is offline ..::kRiiSSi::..
    Vn SS
    Nov 2005
    Cranny
    Question Dash Light (!)
    I had my one of my dash lights come on the other morning which has never come on before and i duno what it is for, its a red exclamation mark in a circle with brackets. Now its coming on every now and again and annoying me!! If anyone knows what it actually is for that would be great???
    My car is a vn ss.
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    is it ur handbrake light or engine light? make sure handbrake is all way down if not check for error codes
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    OFFiTS's Avatar
    Vn SS
    Nov 2005
    Cranny
    Nar it aint the handbrake, and i thought the engine light was the weird orange shaped one? Or it the the trany?
    VYI equipe sedan and vyII acclaim wagon
    Jan 2006
    adelaide
    yeah it's the engine light.
    Ive got a vn ss to and mine started flickering all the time. put a new computer in a presto no more flickering!! you can get a computer off ebay and swap your mecal
    OFFiTS's Avatar
    Vn SS
    Nov 2005
    Cranny
    VY S2 Berlina
    Jul 2005
    Quote Originally Posted by fleet5ltr
    u should of checked for errors, be disapointing in a few days to have the same enigne light flash due to a sensor playing up
    Current: My Ride
    Previous: Ride 2
    missus (in more ways than one)
    Sep 2005
    gee i thourt engine light was the little engine. either way check for errors dude, their are that many threads on checkin codes you'll find one just search (error codes) or somthing, once you have the code number post back here or pm or somthing
    VN Exec to Calais
    May 2006
    Dude, if you dont have a manual, or can't decipher what type of light is flashing on your dash, than you definately should not even attempt to fix your prob, until you definately know what light it is.
    Also, as stated above, if it is the engine light, make sure you check for error codes as the flashing light could be warning you of something.
    In my experience, you don't just swap computers over just because the a light flashes on your dash.
    Thats my 2 cents.
    Frd_thmsn Guest
    Sorry all but it's a brake warning light.
    Your brake fluid might be low , or you have a leak and the brake differential has tripped.Either way check it out immediately.
    The Engine warning lamp is orange, is shaped like an engine , and has an exclamation. This is what the symbol krisi is getting.
    OFFiTS's Avatar
    Vn SS
    Nov 2005
    Cranny
    Frd_thmsn Guest
    No worries.
    You normally only briefly see that light as you start the car, it doesn't come on with ignition, but as the car starts, it checks the circuit for errors comes on then should immediately go out.
    Also there could just be a bad connection . Maybe going over bumps triggers it.
  1. Dash light problem
    By V6VL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2006, 12:18 PM
  2. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  3. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  4. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
  5. dash light
    By VL-187 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-01-2005, 06:18 PM
