Results 1 to 13 of 13
Thread: vn gearbox change
    vr berlina
    May 2006
    Default vn gearbox change
    hello there i am trying to find out if a auto vn can easily be changed over to a manual
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    hey im planning 2 put a 5 speed in a vn in a few weeks it should be fairly straight forward like on previous models (eg vh vk) but iv been told you have to change your computer to 1 out of a vn manual, does anyone know if you do have to change the computer any comments would be much appreciated
    vks chris
    VN series III & Honda VTR250
    May 2005
    sydney
    you'll need a different length tailshaft and a different flywheel. the need for a new computer is a myth as far as i am aware for a VN, you will need to get it reprogrammed however.
    how much did you guys get a T5 for? and what conndition? my laygear bearing have gone up the shit, as with reverse and the syncro rings.
    cheers
    CBR954RR
    XR400R
    dont knock riceburners, they are fast and reliable...
    rare and endanged 94 VR auto white sedan
    vr berlina
    May 2006
    i am only thinking about it i haven't bought any parts yet but i heard the end of the crank is longer on a manual
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    i bought my 5 speed and a sports clutch kit (clutch is a bit worn) from the wreckers it came out of a written off vn S pac was that a good price for the box?
    vks chris
    jazzawithvg Guest
    you will have 2 work out weather your crank has 6 bolts or eight because there are 2 completly different motors and they will not change over unless you change your crank and you need 2 change computer and parts of wirin harness as electronic shifted.
    VN Exec to Calais
    May 2006
    Okay one thing fellas, I just found out that series 1 VN engines do not allow this conversion (manual - auto), only from series 2 engines up can you do the mod, hope this helps. Would hate to see you waste all your time and money for nothing.
    1993 VP Commodore Executive sudan
    Oct 2010
    Ingham N.Q.
    Quote Originally Posted by jazzawithvg View Post
    So far, i've found there is more differentes then just the number of bolts, for the 6 bolt crank there seems to be two size bolt-up's pattens for the fly-wheel, there's a lot more in it then the old day's thats for sure.
    Vn Calais
    Apr 2007
    New Zealand
    If its an early VN dont bother. You will need either an adapter flywheel or Dellow used to do an adapter to fit the 6 bolt manual flywheel onto auto crank flange. Auto or manual computer doesnt matter at all!!!! Don get sucked into paying big money for a "manual" ecu, its a crock. Wiring just has to be altered a little at gearbox, two wires need female spade terminals fitted for reverse light switch and inhibitor wires need bridging, apart from that its basic. If you want to do it , make sure you buy a complete conversion kit, dont buy dribs and drabs..........
    Your talkin to me all wrong, it's the wrong tone. Do it again and I'll stab you in the face with a soldering iron.
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    If you have a series 1 you might find it easier to do what I did and get a manual engine+box combo. I got mine for less than the cost of the adapter plate and it makes for alot less work as its just an engine change. ECU does not matter at all, dont know why its such a common confusion. There is wiring diagrams for the small (easy) changes to the loom to suit the manual box.
    And make sure you do new clutch while your doing it, wasting your time puttin a second hand one in there as its alot easier with it already apart
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    ummm, thread date guys...
    If anyones still interested from 2006,
    V6 Crankshaft Info
    The complete Vn-Vr Manual Conversion Guide.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    lemusa's Avatar
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    ooops missed that one, cheers for the link though. that should be plastered all over the net so people dont have to read peoples "opinions" of what fits with what
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I've got a whole setup good to go with a flywheel adapter
    Silly how they did the VN series ones.
  1. gearbox change?? advice
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-01-2012, 01:31 AM
  2. vr gearbox change over to man
    By shoog in forum General
    Last Post: 03-02-2007, 10:53 PM
  3. How to you change gearbox oil?
    By SMIT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2006, 03:29 PM
  4. I have a VT 99, need to know about gearbox oil change
    By Tani72 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2006, 10:54 PM
  5. v6 t5 gearbox oil change
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2005, 11:49 PM
