Results 1 to 7 of 7
Thread: Cooling fan not turning
    Webster_140db Guest
    Default Cooling fan not turning
    Hey, when i purchased my vn v6 the fan use to run all the time when the ignition was on cos he earthed one of the wires from the back of the cooling fan relay and recently the fan has stop turning all together but the fan still works cos i conected straight to a battery to c if it works, but when connected to the original circuit doesnt spin at so if any one can help me with this confuzing problem it would be very grateful, thanks
    foammedia Guest
    Webster_140db Guest
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Blown fuse, blown fan motor (it can happen) or a dead relay, could be a dodgy themperature sender too.
    Gravity is proof that nature keeps getting us down.
    Webster_140db Guest
    fuses are good relays r good replaced coolant tempreture sensor and the fan is new so i am very confuzed
    VP WAGON V6
    Mar 2006
    just hardwire it into the ingition if it works still. Then it wiill be on all the time.
    mouce's Avatar
    Jul 2005
    If you hardwire it in you'll most likely notice a big jump in fuel consumption. Though hard wiring it in to test it is a good idea. Wire it across the battery just to see if the motor is still good. If it works then you know that the fault lies somewhere in the switching setup.
  1. vh not turning over??????
    By NOT.BT1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2007, 07:11 PM
  2. VS turning off spontaneously
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2007, 10:20 AM
  3. clunking when turning
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 03:39 PM
  4. VS keeps turning off while driving
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2006, 09:45 PM
  5. no powersteering turning right.
    By saville in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2005, 03:06 PM
