Results 1 to 20 of 20
Thread: Pacemaker issues?
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Arrow Pacemaker issues?
    Has anyone fitted Pacemaker extractors and had any problems? Talking specifically about the V6. . . I recall reading about some people having problems with a knocking sound due to their engine mounts being shot, and it just occurred to me to ask whether there are any other issues I should know about?
    I'm getting a set installed in the next month or so, so I figure the more I know about possible problems beforehand, the less heartache I'll have later.
    Cheers,
    Sam
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    The only issue I had is that the auto crossmember had to be trim abit because of rubbing which was not a major problem.
    I've had no problems for 3-4years when the extractors were fitted to the vn.
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    if an engine mount is shot it wont be because of the extractors doing it, it might have been a coincidence that the mounts went at the same time but yeh the knocking would have been the mounts as it allows the engine to move more than normal.
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    Tata Guest
    I've fitted pacemakers to my vn 1990 manual v6,no problems there!Just make sure of body floor clearance or you will get a knocking sound,but real easy re-adjusted.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Cheers for the info guys. How easy is it to inspect engine mounts? Could I do it myself? (Given that at the moment I don't even know which part they are...)
    VX HSV Clubsport
    Jun 2005
    im not sure how you can check them without a hoist, but i was watching the mechanic chech mine and he hoisted it up and got a lever and levered the engine side to side to look (hope that makes sense)
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    yea i know what you mean. maybe, just maybe, i CAN get my car on a hoist. i think they got one here at uni, in one of the workshops
    might see if i can use it sometime...
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    make sure once you get it done a month later you go back to the workshop to get it all tightened and re checked. Most exhaust places will offer to do this for free after installation.
    VT Calais Super6
    Jun 2005
    It will be your engine mounts, mine are stuffed and cause the motor to shift and hit the Y piece on the floor on the passanger side.
    92 vp berlina
    Sep 2004
    west aussie
    i got my pacies in about ....7 months ago. they knocked a bit at first when i put it in reverse but havent done that for quite some time now...and i havent touched anything, it just went away. good choice!
    jokes..ahahaha i get jokes
    xlr8_87's Avatar
    xlr8_87 is offline No longer a commy driver
    '96 Prado 4x4
    Mar 2006
    Melb, VIC
    had mine fitted on manual VP V6, mechanic needed to bend it a little to clear the floor but havnt had any problems with them at all!
    <<<Rob>>>
    Ecotec VP, 135rwkw, 427nm
    wes_v8's Avatar
    wes_v8 is offline WES_VN
    04 Vz Sv6 6 speed
    Jun 2005
    Maitland near Newcaslte N.S.W
    yea would be helpful 2 get sum more info on these extractors cause i wouldn't mind having a set of extractors on my v6
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I noticed that on the Pacemaker website their VN V6 extractors (both variants) have only got a 2.25" outlet pipe. Doesn't that defeat the purpose of my 2.5" cat-back??
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I installed my V6 pacemakers along with rest of zorst, the only think havent replaced is the cat converter. I have had a knock since installation but i think that may be due to my gearbox oil lines being loose and close to the headers. Other then that they wont on prety smoothly. Apart from me not knowing what the steering knuckle was and how to remove it! It was all done and worked well in the end. Done it on some ramps at a mates house.
  15. #15
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Awesome - how long did the install take?? Because if I can get hold of a hoist here at Uni then I'd be happy to give it a go myself...
  16. #16
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    About a day after multiple drink breaks, food breaks and swearing at the steering arm knuckle.
  17. #17
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK, cheers for that. Maybe I will pay for the installation then . . . probably worth the money
  18. #18
    missus (in more ways than one)
    Sep 2005
    it took me about 5 hours to get my genie extractors on. passenger side no worries, but drivers side, ive never sworn so much, such a bitch, and yeah mine knocks in reverse when it's cold, but it alright after thast
  19. #19
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I asked how much fitting was, they said like $300, So i was like 'stuff yooo noob' and done it myself. Just like my gearbox, $400 installation, 'stoof yoo noob' and done it myself.
  20. #20
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Hmm. Strikes me as a fair call. It takes me 2 weeks to earn $400 . . .
  1. HM or pacemaker
    By ryan_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2009, 07:16 PM
  2. pacemaker
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2007, 05:01 PM
  3. Pacemaker
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 07:33 PM
  4. w.t.b Pacemaker extractors
    By executive_power in forum Swap / Wanted to Buy / Trade
    Last Post: 04-02-2006, 11:20 PM
